Date/Time: Mon, 10 Mar 2025 02:46:50 +0000
Realtime data feed for BBH22_FUT_CME and other Nymex, CBOT, COMEX
View Count: 455
[2022-03-16 12:34:19]
David Abrahams - Posts: 17
Good morning...
I have tried all the settings and solutions suggested, I can seem to get Real Time data for anything other than S&P e mini..
See attached message log.
Can you help me please?
Thanks in advance
imageMessageLog_16March.PNG / V - Attached On 2022-03-16 12:33:04 UTC - Size: 30.15 KB - 125 views
[2022-03-16 12:43:16]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-03-16 13:30:49]
Thanks for yoiur quick reply...
HereĀ“s an example of a symbol as requested...BBH22_FUT_CME
Please also see attached foto and below message log.
I hope this helps.
Reading Internal Order ID file. | 2022-03-16 12:02:01.270
Reading Trade Orders file. | 2022-03-16 12:02:01.459
Reading Trade Positions file. | 2022-03-16 12:02:01.461
Reading Trade Account Data files. | 2022-03-16 12:02:01.462
Software version: 2368 64-bit | 2022-03-16 12:02:01.512
Primary Thread ID: 9816 | 2022-03-16 12:02:01.512
Usage end date: 2022-06-02 | 2022-03-16 12:02:01.512
Enabled for: Advanced Features 2. | 2022-03-16 12:02:01.512
Enabled for: Sierra Chart Historical Data Service. | 2022-03-16 12:02:01.512
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-03-16 12:02:01.512
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-16 12:02:01.512
Enabled for exchange2: CME (Trading Account Required) | 2022-03-16 12:02:01.512
Enabled for exchange2: CBOT (Trading Account Required) | 2022-03-16 12:02:01.512
Enabled for exchange2: COMEX (Trading Account Required) | 2022-03-16 12:02:01.512
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-03-16 12:02:01.512
Enabled for exchange2: fairx_exchange.data | 2022-03-16 12:02:01.512
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-16 12:02:01.512
Current selected Data/Trading service: Teton CME Order Routing | 2022-03-16 12:02:01.512
Custom symbol settings values: enabled | 2022-03-16 12:02:01.512
Chart Update Interval: 500 | 2022-03-16 12:02:01.512
Intraday Data Storage Time Unit: 0 | 2022-03-16 12:02:01.512
Time Zone: +00:00:00 (UTC+00) | 2022-03-16 12:02:01.512
2022-03-16 12:02:01 Local computer time in UTC | 2022-03-16 12:02:01.512
2022-03-16 12:02:01 Local computer time in SC Time Zone | 2022-03-16 12:02:01.512
2022-03-16 12:02:01 Server time in UTC | 2022-03-16 12:02:01.512
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-03-16 12:02:01.512
Program path: C:\SierraChart\ | 2022-03-16 12:02:01.512
Data Files path: C:\SierraChart\Data\ | 2022-03-16 12:02:01.512
OS Version Number: 10.0 | 2022-03-16 12:02:01.512
Locale Setting: C | 2022-03-16 12:02:01.512
DLLs: UserContributedStudies_64.dll | 2022-03-16 12:02:01.512
Allowed protected custom studies: | 2022-03-16 12:02:01.512
Crash reporter started: true | 2022-03-16 12:02:01.512
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2022-03-16 12:02:01.513
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:02:01.597
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-16 12:02:01.667
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-16 12:02:01.667
Received 5 login tokens. | 2022-03-16 12:02:01.736
Symbol settings MD5 received. Request ID: 1. | 2022-03-16 12:02:03.103
Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2022-03-16 12:02:03.103
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-16 12:02:07.867
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-16 12:02:07.956
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-16 12:02:07.956
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-16 12:02:07.956
Teton CME Order Routing | Network connection to server complete. | 2022-03-16 12:02:08.071
Teton CME Order Routing | Starting socket receive thread. | 2022-03-16 12:02:08.071
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-03-16 12:02:08.071
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-03-16 12:02:08.416
Teton CME Order Routing | Sending logon request message. | 2022-03-16 12:02:08.416
Teton CME Order Routing | Received logon response. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Server Name: SC DTC Server. Build=41200. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-03-16 12:02:08.994
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Trading is supported. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Order cancel and replace is supported. | 2022-03-16 12:02:08.994
Teton CME Order Routing | OCO Orders supported. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Bracket Orders supported. | 2022-03-16 12:02:08.994
Teton CME Order Routing | Connected to server complete. | 2022-03-16 12:02:08.994
Triggering next historical data download in queue. | 2022-03-16 12:02:08.995
No download requests in the queue to start downloads for. | 2022-03-16 12:02:09.001
Updated verified funded futures trading account ending date to: 2022-04-15 12:02:09 | 2022-03-16 12:02:09.114
CLJ22-NYMEX [CBV] #2 | Reloading chart. | 2022-03-16 12:03:42.162
CLJ22-NYMEX [CBV] #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 12:03:42.163
CLJ22-NYMEX [CBV] #2 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 12:03:42.163
CLJ22-NYMEX [CBV] 2000 Volume #3 | Reloading chart. | 2022-03-16 12:03:42.273
CLJ22-NYMEX [CBV] 2000 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 12:03:42.273
CLJ22-NYMEX [CBV] 2000 Volume #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 12:03:42.273
BBH22_FUT_CME [CBV] 2000 Volume #4 | Reloading chart. | 2022-03-16 12:03:42.377
Starting DelayedDownloadMonitoringTimer | 2022-03-16 12:03:42.385
Starting HDTimeoutTimer | 2022-03-16 12:03:42.385
Added historical Intraday data request for BBJ21_FUT_CME to the queue. | 2022-03-16 12:03:42.386
Triggering next historical data download in queue. | 2022-03-16 12:03:42.386
Added historical Intraday data request for BBK21_FUT_CME to the queue. | 2022-03-16 12:03:42.392
Added historical Intraday data request for BBM21_FUT_CME to the queue. | 2022-03-16 12:03:42.399
Added historical Intraday data request for BBN21_FUT_CME to the queue. | 2022-03-16 12:03:42.407
BBH22_FUT_CME [CBV] 2000 Volume #4 | Performing continuous chart historical Daily data download for symbol BBN21_FUT_CME starting at last date in file. | 2022-03-16 12:03:42.409
Starting DelayedDownloadMonitoringTimer | 2022-03-16 12:03:42.410
Starting HDTimeoutTimer | 2022-03-16 12:03:42.410
Added historical Daily data request for BBN21_FUT_CME to the queue. | 2022-03-16 12:03:42.410
Triggering next historical data download in queue. | 2022-03-16 12:03:42.410
Added historical Intraday data request for BBQ21_FUT_CME to the queue. | 2022-03-16 12:03:42.413
Added historical Intraday data request for BBU21_FUT_CME to the queue. | 2022-03-16 12:03:42.420
Added historical Intraday data request for BBV21_FUT_CME to the queue. | 2022-03-16 12:03:42.424
BBH22_FUT_CME [CBV] 2000 Volume #4 | Performing continuous chart historical Daily data download for symbol BBV21_FUT_CME starting at last date in file. | 2022-03-16 12:03:42.427
Added historical Daily data request for BBV21_FUT_CME to the queue. | 2022-03-16 12:03:42.427
Added historical Intraday data request for BBX21_FUT_CME to the queue. | 2022-03-16 12:03:42.433
Added historical Intraday data request for BBZ21_FUT_CME to the queue. | 2022-03-16 12:03:42.440
Added historical Intraday data request for BBF22_FUT_CME to the queue. | 2022-03-16 12:03:42.444
Added historical Intraday data request for BBG22_FUT_CME to the queue. | 2022-03-16 12:03:42.452
Added historical Intraday data request for BBH22_FUT_CME to the queue. | 2022-03-16 12:03:42.456
BBH22_FUT_CME [CBV] 2000 Volume #4 | Performing continuous chart historical Daily data download for symbol BBH22_FUT_CME starting at last date in file. | 2022-03-16 12:03:42.458
Added historical Daily data request for BBH22_FUT_CME to the queue. | 2022-03-16 12:03:42.458
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2021-12-31. | 2022-03-16 12:03:42.470
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2022-03-16. | 2022-03-16 12:03:42.470
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-11-30. | 2022-03-16 12:03:42.482
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-12-30. | 2022-03-16 12:03:42.482
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-10-29. | 2022-03-16 12:03:42.495
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-11-29. | 2022-03-16 12:03:42.495
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-09-30. | 2022-03-16 12:03:42.509
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-10-28. | 2022-03-16 12:03:42.509
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-08-31. | 2022-03-16 12:03:42.519
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-09-29. | 2022-03-16 12:03:42.519
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-07-30. | 2022-03-16 12:03:42.528
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-08-30. | 2022-03-16 12:03:42.528
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-06-30. | 2022-03-16 12:03:42.538
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-07-29. | 2022-03-16 12:03:42.538
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-05-31. | 2022-03-16 12:03:42.548
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-06-29. | 2022-03-16 12:03:42.548
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-04-30. | 2022-03-16 12:03:42.556
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-05-28. | 2022-03-16 12:03:42.556
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-03-31. | 2022-03-16 12:03:42.567
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-04-29. | 2022-03-16 12:03:42.567
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-02-26. | 2022-03-16 12:03:42.578
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-03-30. | 2022-03-16 12:03:42.578
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-01-29. | 2022-03-16 12:03:42.586
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-02-25. | 2022-03-16 12:03:42.586
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2020-12-31. | 2022-03-16 12:03:42.593
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2021-01-28. | 2022-03-16 12:03:42.593
BBH22_FUT_CME [CBV] 2000 Volume #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, | 2022-03-16 12:03:42.593
CLJ22-NYMEX #5 | Reloading chart. | 2022-03-16 12:03:42.669
CLJ22-NYMEX [CBV] 5 Min #6 | Reloading chart. | 2022-03-16 12:03:42.766
CLJ22-NYMEX [CBV] 5 Min #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 12:03:42.766
CLJ22-NYMEX [CBV] 5 Min #6 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 12:03:42.766
CLJ22-NYMEX/CLJ22-NYMEX Renko 6t #7 | Reloading chart. | 2022-03-16 12:03:42.879
Mapping BBK22_FUT_CME to BBK22. Service code: nymex | 2022-03-16 12:03:42.945
Using symbol data fast lookup vector | 2022-03-16 12:03:42.945
SC Data - All Services | Starting real-time market data updates for: BBK22_FUT_CME (BBK22). ID: 1 Service code: nymex | 2022-03-16 12:03:42.945
SC Data - All Services | Connecting to the server ds6-2.sierracharts.com. Port 443 | 2022-03-16 12:03:42.945
SC Data - All Services | Requesting security definition data for: BBK22_FUT_CME (BBK22). ID: 1 | 2022-03-16 12:03:42.945
Mapping BBM22_FUT_CME to BBM22. Service code: nymex | 2022-03-16 12:03:42.946
SC Data - All Services | Starting real-time market data updates for: BBM22_FUT_CME (BBM22). ID: 2 Service code: nymex | 2022-03-16 12:03:42.947
SC Data - All Services | Requesting security definition data for: BBM22_FUT_CME (BBM22). ID: 2 | 2022-03-16 12:03:42.947
Mapping BBN22_FUT_CME to BBN22. Service code: nymex | 2022-03-16 12:03:42.947
SC Data - All Services | Starting real-time market data updates for: BBN22_FUT_CME (BBN22). ID: 3 Service code: nymex | 2022-03-16 12:03:42.948
SC Data - All Services | Requesting security definition data for: BBN22_FUT_CME (BBN22). ID: 3 | 2022-03-16 12:03:42.948
Mapping BBQ22_FUT_CME to BBQ22. Service code: nymex | 2022-03-16 12:03:42.949
SC Data - All Services | Starting real-time market data updates for: BBQ22_FUT_CME (BBQ22). ID: 4 Service code: nymex | 2022-03-16 12:03:42.950
SC Data - All Services | Requesting security definition data for: BBQ22_FUT_CME (BBQ22). ID: 4 | 2022-03-16 12:03:42.950
Mapping BBU22_FUT_CME to BBU22. Service code: nymex | 2022-03-16 12:03:42.950
SC Data - All Services | Starting real-time market data updates for: BBU22_FUT_CME (BBU22). ID: 5 Service code: nymex | 2022-03-16 12:03:42.951
SC Data - All Services | Requesting security definition data for: BBU22_FUT_CME (BBU22). ID: 5 | 2022-03-16 12:03:42.951
Mapping BBV22_FUT_CME to BBV22. Service code: nymex | 2022-03-16 12:03:42.951
SC Data - All Services | Starting real-time market data updates for: BBV22_FUT_CME (BBV22). ID: 6 Service code: nymex | 2022-03-16 12:03:42.952
SC Data - All Services | Requesting security definition data for: BBV22_FUT_CME (BBV22). ID: 6 | 2022-03-16 12:03:42.952
Mapping BBX22_FUT_CME to BBX22. Service code: nymex | 2022-03-16 12:03:42.953
SC Data - All Services | Starting real-time market data updates for: BBX22_FUT_CME (BBX22). ID: 7 Service code: nymex | 2022-03-16 12:03:42.953
SC Data - All Services | Requesting security definition data for: BBX22_FUT_CME (BBX22). ID: 7 | 2022-03-16 12:03:42.953
CLJ22-NYMEX [CBV-D] #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 12:03:42.971
DTC Client socket (2) | Creating socket. | 2022-03-16 12:03:42.973
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-16 12:03:42.973
DTC Client socket (2) | Connecting to IP: 51.195.180.15. | 2022-03-16 12:03:42.973
CLJ22-NYMEX [CBV-D] 2000 Volume #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 12:03:42.982
Mapping BBJ21_FUT_CME to BBJ21. Service code: nymex | 2022-03-16 12:03:42.994
HD Request # 1 | Downloading Intraday chart data for BBJ21_FUT_CME to the file BBJ21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:42.994
HD Request # 1 | Download start date-time: 2021-01-14 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:42.995
HD Request # 1 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:42.995
Mapping BBN21_FUT_CME to BBN21. Service code: nymex | 2022-03-16 12:03:42.995
Socket (3) | Creating socket. | 2022-03-16 12:03:42.997
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:42.997
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:42.997
HD Request # 2 | Downloading Historical Daily chart data for BBN21_FUT_CME. Starting date: 2021-05-25. Service: sc_futures_direct.dtc.trading | 2022-03-16 12:03:43.004
CLJ22-NYMEX #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:03:43.050
CLJ22-NYMEX [CBV-D] 5 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 12:03:43.057
CLJ22-NYMEX/CLJ22-NYMEX Renko 6t #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 12:03:43.066
SC Data - All Services | Network connection to server complete. | 2022-03-16 12:03:43.077
SC Data - All Services | Starting socket receive thread. | 2022-03-16 12:03:43.078
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-16 12:03:43.078
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBK22_FUT_CME | 2022-03-16 12:03:43.091
Teton CME Order Routing | Received security definition for symbol BBK22_FUT_CME | 2022-03-16 12:03:43.091
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBM22_FUT_CME | 2022-03-16 12:03:43.092
Teton CME Order Routing | Received security definition for symbol BBM22_FUT_CME | 2022-03-16 12:03:43.092
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBN22_FUT_CME | 2022-03-16 12:03:43.092
Teton CME Order Routing | Received security definition for symbol BBN22_FUT_CME | 2022-03-16 12:03:43.092
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:43.122
SC Data - All Services | Sending logon request message. | 2022-03-16 12:03:43.122
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBQ22_FUT_CME | 2022-03-16 12:03:43.187
Teton CME Order Routing | Received security definition for symbol BBQ22_FUT_CME | 2022-03-16 12:03:43.187
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBU22_FUT_CME | 2022-03-16 12:03:43.187
Teton CME Order Routing | Received security definition for symbol BBU22_FUT_CME | 2022-03-16 12:03:43.187
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBV22_FUT_CME | 2022-03-16 12:03:43.187
Teton CME Order Routing | Received security definition for symbol BBV22_FUT_CME | 2022-03-16 12:03:43.187
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBX22_FUT_CME | 2022-03-16 12:03:43.187
Teton CME Order Routing | Received security definition for symbol BBX22_FUT_CME | 2022-03-16 12:03:43.187
Teton CME Order Routing | Starting real-time market data updates for: CLJ22-NYMEX. ID: 10 | 2022-03-16 12:03:43.187
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: CLJ22-NYMEX | 2022-03-16 12:03:43.187
Teton CME Order Routing | Requesting security definition data for: CLJ22-NYMEX. ID: 10 | 2022-03-16 12:03:43.187
No historical data client is currently set to download historical Intraday data for CLJ22-NYMEX. | 2022-03-16 12:03:43.187
Real-time Intraday chart data file updates started for CLJ22-NYMEX | 2022-03-16 12:03:43.187
Intraday chart data file opened for CLJ22-NYMEX | 2022-03-16 12:03:43.187
HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:43.222
HD Request # 1 | Sending historical data logon request message. | 2022-03-16 12:03:43.222
Teton CME Order Routing | Received security definition for symbol CLJ22-NYMEX | 2022-03-16 12:03:43.300
HD Request # 2 | Requesting historical Daily data for SCN21 starting at 2021-05-24. SC External HD service. | 2022-03-16 12:03:43.386
HD Request # 2 | Receiving historical Daily data for BBN21_FUT_CME starting at 2021-05-25 | 2022-03-16 12:03:43.623
HD Request # 2 | Writing historical Daily data to the file BBN21_FUT_CME.dly | 2022-03-16 12:03:43.625
HD Request # 2 | Bytes received: 180 | 2022-03-16 12:03:43.665
HD Request # 2 | Received 4 Daily data records from 2021-05-25 00:00:00 to 2021-05-27 00:00:00 (3.0 days) and wrote 3 records for BBN21_FUT_CME | 2022-03-16 12:03:43.665
HD Request # 2 | Completion time: 1s | 2022-03-16 12:03:43.666
HD Request # 2 | Daily data download complete for BBN21_FUT_CME. Unique request ID: 5 | 2022-03-16 12:03:43.666
Removing historical data download ID 5. | 2022-03-16 12:03:43.666
Triggering next historical data download in queue. | 2022-03-16 12:03:43.666
Mapping BBV21_FUT_CME to BBV21. Service code: nymex | 2022-03-16 12:03:43.666
HD Request # 3 | Downloading Historical Daily chart data for BBV21_FUT_CME. Starting date: 2021-08-25. Service: sc_futures_direct.dtc.trading | 2022-03-16 12:03:43.669
SC Data - All Services | Received logon response. | 2022-03-16 12:03:43.669
SC Data - All Services | Server Name: SC Realtime Server. | 2022-03-16 12:03:43.669
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-03-16 12:03:43.669
SC Data - All Services | Successfully connected. | 2022-03-16 12:03:43.669
SC Data - All Services | Trading is not supported. | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBK22_FUT_CME -> BBK22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBM22_FUT_CME -> BBM22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBN22_FUT_CME -> BBN22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBQ22_FUT_CME -> BBQ22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBU22_FUT_CME -> BBU22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBV22_FUT_CME -> BBV22 | 2022-03-16 12:03:43.669
SC Data - All Services | Restarting real-time data updates for symbol: BBX22_FUT_CME -> BBX22 | 2022-03-16 12:03:43.669
HD Request # 1 | Requesting Intraday data. Start date-time: 2021-01-14 00:00:00. Record interval: 0. Symbol: BBJ21 | 2022-03-16 12:03:43.782
SC Data - All Services | Received security definition for symbol BBK22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBM22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBN22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBQ22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBU22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBV22_FUT_CME | 2022-03-16 12:03:43.791
SC Data - All Services | Received security definition for symbol BBX22_FUT_CME | 2022-03-16 12:03:43.791
HD Request # 1 | Decompressing data. | 2022-03-16 12:03:43.888
Socket (3) | CloseSocket call. | 2022-03-16 12:03:43.888
Historical data download thread signaled to stop. | 2022-03-16 12:03:43.889
HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBJ21_FUT_CME | 2022-03-16 12:03:43.889
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:43.889
HD Request # 1 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:43.889
HD Request # 1 | Completion time: 1s | 2022-03-16 12:03:43.890
HD Request # 1 | Intraday data download complete for BBJ21_FUT_CME. Unique request ID: 1 | 2022-03-16 12:03:43.890
Removing historical data download ID 1. | 2022-03-16 12:03:43.890
Real-time Intraday chart data file updates started for BBJ21_FUT_CME | 2022-03-16 12:03:43.890
Intraday chart data file opened for BBJ21_FUT_CME | 2022-03-16 12:03:43.890
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:43.890
Triggering next historical data download in queue. | 2022-03-16 12:03:43.890
Mapping BBK21_FUT_CME to BBK21. Service code: nymex | 2022-03-16 12:03:43.890
HD Request # 4 | Downloading Intraday chart data for BBK21_FUT_CME to the file BBK21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:43.890
HD Request # 4 | Download start date-time: 2021-02-11 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:43.890
HD Request # 4 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:43.890
Socket (4) | Creating socket. | 2022-03-16 12:03:43.891
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 12:03:43.891
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:43.891
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:43.993
Socket (3) | Closed. | 2022-03-16 12:03:43.993
HD Request # 3 | Requesting historical Daily data for SCV21 starting at 2021-08-24. SC External HD service. | 2022-03-16 12:03:44.023
Requesting market depth updates for: CLJ22-NYMEX if supported. | 2022-03-16 12:03:44.052
Separate subscription for market depth updates not supported. CLJ22-NYMEX | 2022-03-16 12:03:44.052
HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:44.111
HD Request # 4 | Sending historical data logon request message. | 2022-03-16 12:03:44.111
HD Request # 3 | Receiving historical Daily data for BBV21_FUT_CME starting at 2021-08-25 | 2022-03-16 12:03:44.182
HD Request # 3 | Writing historical Daily data to the file BBV21_FUT_CME.dly | 2022-03-16 12:03:44.183
HD Request # 3 | Bytes received: 176 | 2022-03-16 12:03:44.214
HD Request # 3 | Received 4 Daily data records from 2021-08-25 00:00:00 to 2021-08-27 00:00:00 (3.0 days) and wrote 3 records for BBV21_FUT_CME | 2022-03-16 12:03:44.214
HD Request # 3 | Completion time: 1s | 2022-03-16 12:03:44.214
HD Request # 3 | Daily data download complete for BBV21_FUT_CME. Unique request ID: 9 | 2022-03-16 12:03:44.214
Removing historical data download ID 9. | 2022-03-16 12:03:44.214
Triggering next historical data download in queue. | 2022-03-16 12:03:44.214
Mapping BBH22_FUT_CME to BBH22. Service code: nymex | 2022-03-16 12:03:44.215
HD Request # 5 | Downloading Historical Daily chart data for BBH22_FUT_CME. Starting date: 2022-01-26. Service: sc_futures_direct.dtc.trading | 2022-03-16 12:03:44.218
HD Request # 5 | Requesting historical Daily data for SCH22 starting at 2022-01-25. SC External HD service. | 2022-03-16 12:03:44.574
HD Request # 4 | Requesting Intraday data. Start date-time: 2021-02-11 00:00:00. Record interval: 0. Symbol: BBK21 | 2022-03-16 12:03:44.669
HD Request # 4 | Decompressing data. | 2022-03-16 12:03:44.773
Socket (4) | CloseSocket call. | 2022-03-16 12:03:44.774
Historical data download thread signaled to stop. | 2022-03-16 12:03:44.774
HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBK21_FUT_CME | 2022-03-16 12:03:44.774
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:44.774
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:44.775
HD Request # 4 | Completion time: 1s | 2022-03-16 12:03:44.775
HD Request # 4 | Intraday data download complete for BBK21_FUT_CME. Unique request ID: 2 | 2022-03-16 12:03:44.775
Removing historical data download ID 2. | 2022-03-16 12:03:44.775
Real-time Intraday chart data file updates started for BBK21_FUT_CME | 2022-03-16 12:03:44.775
Intraday chart data file opened for BBK21_FUT_CME | 2022-03-16 12:03:44.775
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:44.775
Triggering next historical data download in queue. | 2022-03-16 12:03:44.775
Mapping BBM21_FUT_CME to BBM21. Service code: nymex | 2022-03-16 12:03:44.775
HD Request # 6 | Downloading Intraday chart data for BBM21_FUT_CME to the file BBM21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:44.775
HD Request # 6 | Download start date-time: 2021-03-16 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:44.776
HD Request # 6 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:44.776
Socket (6) | Creating socket. | 2022-03-16 12:03:44.776
Socket (6) | New receive buffer size: 5242880 | 2022-03-16 12:03:44.776
Socket (6) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:44.776
HD Request # 5 | Receiving historical Daily data for BBH22_FUT_CME starting at 2022-01-26 | 2022-03-16 12:03:44.813
HD Request # 5 | Writing historical Daily data to the file BBH22_FUT_CME.dly | 2022-03-16 12:03:44.814
HD Request # 5 | Bytes received: 176 | 2022-03-16 12:03:44.837
HD Request # 5 | Received 4 Daily data records from 2022-01-26 00:00:00 to 2022-01-28 00:00:00 (3.0 days) and wrote 3 records for BBH22_FUT_CME | 2022-03-16 12:03:44.837
HD Request # 5 | Completion time: 0s | 2022-03-16 12:03:44.837
HD Request # 5 | Daily data download complete for BBH22_FUT_CME. Unique request ID: 15 | 2022-03-16 12:03:44.837
Removing historical data download ID 15. | 2022-03-16 12:03:44.837
Triggering next historical data download in queue. | 2022-03-16 12:03:44.837
No download requests in the queue to start downloads for. | 2022-03-16 12:03:44.838
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 12:03:44.878
Socket (4) | Closed. | 2022-03-16 12:03:44.878
HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:45.009
HD Request # 6 | Sending historical data logon request message. | 2022-03-16 12:03:45.009
HD Request # 6 | Requesting Intraday data. Start date-time: 2021-03-16 00:00:00. Record interval: 0. Symbol: BBM21 | 2022-03-16 12:03:45.119
HD Request # 6 | Decompressing data. | 2022-03-16 12:03:45.227
Socket (6) | CloseSocket call. | 2022-03-16 12:03:45.228
Historical data download thread signaled to stop. | 2022-03-16 12:03:45.228
HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBM21_FUT_CME | 2022-03-16 12:03:45.228
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:45.228
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:45.228
HD Request # 6 | Completion time: 1s | 2022-03-16 12:03:45.228
HD Request # 6 | Intraday data download complete for BBM21_FUT_CME. Unique request ID: 3 | 2022-03-16 12:03:45.228
Removing historical data download ID 3. | 2022-03-16 12:03:45.228
Real-time Intraday chart data file updates started for BBM21_FUT_CME | 2022-03-16 12:03:45.228
Intraday chart data file opened for BBM21_FUT_CME | 2022-03-16 12:03:45.228
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:45.228
Triggering next historical data download in queue. | 2022-03-16 12:03:45.228
HD Request # 7 | Downloading Intraday chart data for BBN21_FUT_CME to the file BBN21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:45.228
HD Request # 7 | Download start date-time: 2021-04-15 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:45.229
HD Request # 7 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:45.229
Socket (3) | Creating socket. | 2022-03-16 12:03:45.229
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:45.229
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:45.229
Socket (6) | Socket gracefully closed by remote side. | 2022-03-16 12:03:45.335
Socket (6) | Closed. | 2022-03-16 12:03:45.335
HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:45.444
HD Request # 7 | Sending historical data logon request message. | 2022-03-16 12:03:45.444
HD Request # 7 | Requesting Intraday data. Start date-time: 2021-04-15 00:00:00. Record interval: 0. Symbol: BBN21 | 2022-03-16 12:03:45.549
HD Request # 7 | Decompressing data. | 2022-03-16 12:03:45.654
Socket (3) | CloseSocket call. | 2022-03-16 12:03:45.656
Historical data download thread signaled to stop. | 2022-03-16 12:03:45.656
HD Request # 7 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBN21_FUT_CME | 2022-03-16 12:03:45.656
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:45.656
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:45.658
HD Request # 7 | Completion time: 0s | 2022-03-16 12:03:45.658
HD Request # 7 | Intraday data download complete for BBN21_FUT_CME. Unique request ID: 4 | 2022-03-16 12:03:45.658
Removing historical data download ID 4. | 2022-03-16 12:03:45.658
Real-time Intraday chart data file updates started for BBN21_FUT_CME | 2022-03-16 12:03:45.658
Intraday chart data file opened for BBN21_FUT_CME | 2022-03-16 12:03:45.658
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:45.658
Triggering next historical data download in queue. | 2022-03-16 12:03:45.658
Mapping BBQ21_FUT_CME to BBQ21. Service code: nymex | 2022-03-16 12:03:45.658
HD Request # 8 | Downloading Intraday chart data for BBQ21_FUT_CME to the file BBQ21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:45.658
HD Request # 8 | Download start date-time: 2021-05-14 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:45.660
HD Request # 8 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:45.660
Socket (4) | Creating socket. | 2022-03-16 12:03:45.660
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 12:03:45.660
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:45.660
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:45.762
Socket (3) | Closed. | 2022-03-16 12:03:45.762
HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:45.903
HD Request # 8 | Sending historical data logon request message. | 2022-03-16 12:03:45.903
HD Request # 8 | Requesting Intraday data. Start date-time: 2021-05-14 00:00:00. Record interval: 0. Symbol: BBQ21 | 2022-03-16 12:03:46.020
HD Request # 8 | Decompressing data. | 2022-03-16 12:03:46.135
Socket (4) | CloseSocket call. | 2022-03-16 12:03:46.136
Historical data download thread signaled to stop. | 2022-03-16 12:03:46.136
HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBQ21_FUT_CME | 2022-03-16 12:03:46.136
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:46.136
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:46.137
HD Request # 8 | Completion time: 1s | 2022-03-16 12:03:46.137
HD Request # 8 | Intraday data download complete for BBQ21_FUT_CME. Unique request ID: 6 | 2022-03-16 12:03:46.137
Removing historical data download ID 6. | 2022-03-16 12:03:46.137
Real-time Intraday chart data file updates started for BBQ21_FUT_CME | 2022-03-16 12:03:46.137
Intraday chart data file opened for BBQ21_FUT_CME | 2022-03-16 12:03:46.137
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:46.137
Triggering next historical data download in queue. | 2022-03-16 12:03:46.137
Mapping BBU21_FUT_CME to BBU21. Service code: nymex | 2022-03-16 12:03:46.137
HD Request # 9 | Downloading Intraday chart data for BBU21_FUT_CME to the file BBU21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:46.137
HD Request # 9 | Download start date-time: 2021-06-15 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:46.138
HD Request # 9 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:46.138
Socket (3) | Creating socket. | 2022-03-16 12:03:46.138
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:46.138
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:46.138
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 12:03:46.251
Socket (4) | Closed. | 2022-03-16 12:03:46.251
HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:46.369
HD Request # 9 | Sending historical data logon request message. | 2022-03-16 12:03:46.369
HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-15 00:00:00. Record interval: 0. Symbol: BBU21 | 2022-03-16 12:03:46.480
HD Request # 9 | Decompressing data. | 2022-03-16 12:03:46.593
Socket (3) | CloseSocket call. | 2022-03-16 12:03:46.594
Historical data download thread signaled to stop. | 2022-03-16 12:03:46.595
HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBU21_FUT_CME | 2022-03-16 12:03:46.595
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:46.595
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:46.597
HD Request # 9 | Completion time: 0s | 2022-03-16 12:03:46.597
HD Request # 9 | Intraday data download complete for BBU21_FUT_CME. Unique request ID: 7 | 2022-03-16 12:03:46.597
Removing historical data download ID 7. | 2022-03-16 12:03:46.597
Real-time Intraday chart data file updates started for BBU21_FUT_CME | 2022-03-16 12:03:46.597
Intraday chart data file opened for BBU21_FUT_CME | 2022-03-16 12:03:46.597
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:46.597
Triggering next historical data download in queue. | 2022-03-16 12:03:46.597
HD Request # 10 | Downloading Intraday chart data for BBV21_FUT_CME to the file BBV21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:46.597
HD Request # 10 | Download start date-time: 2021-07-15 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:46.598
HD Request # 10 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:46.599
Socket (4) | Creating socket. | 2022-03-16 12:03:46.599
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 12:03:46.599
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:46.599
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:46.707
Socket (3) | Closed. | 2022-03-16 12:03:46.707
HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:46.845
HD Request # 10 | Sending historical data logon request message. | 2022-03-16 12:03:46.845
HD Request # 10 | Requesting Intraday data. Start date-time: 2021-07-15 00:00:00. Record interval: 0. Symbol: BBV21 | 2022-03-16 12:03:46.957
HD Request # 10 | Decompressing data. | 2022-03-16 12:03:47.069
Socket (4) | CloseSocket call. | 2022-03-16 12:03:47.069
Historical data download thread signaled to stop. | 2022-03-16 12:03:47.070
HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBV21_FUT_CME | 2022-03-16 12:03:47.070
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:47.070
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:47.070
HD Request # 10 | Completion time: 1s | 2022-03-16 12:03:47.070
HD Request # 10 | Intraday data download complete for BBV21_FUT_CME. Unique request ID: 8 | 2022-03-16 12:03:47.070
Removing historical data download ID 8. | 2022-03-16 12:03:47.070
Real-time Intraday chart data file updates started for BBV21_FUT_CME | 2022-03-16 12:03:47.070
Intraday chart data file opened for BBV21_FUT_CME | 2022-03-16 12:03:47.070
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:47.070
Triggering next historical data download in queue. | 2022-03-16 12:03:47.070
Mapping BBX21_FUT_CME to BBX21. Service code: nymex | 2022-03-16 12:03:47.071
HD Request # 11 | Downloading Intraday chart data for BBX21_FUT_CME to the file BBX21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:47.071
HD Request # 11 | Download start date-time: 2021-08-16 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:47.071
HD Request # 11 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:47.071
Socket (3) | Creating socket. | 2022-03-16 12:03:47.071
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:47.071
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:47.071
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 12:03:47.181
Socket (4) | Closed. | 2022-03-16 12:03:47.181
HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:47.307
HD Request # 11 | Sending historical data logon request message. | 2022-03-16 12:03:47.307
HD Request # 11 | Requesting Intraday data. Start date-time: 2021-08-16 00:00:00. Record interval: 0. Symbol: BBX21 | 2022-03-16 12:03:47.422
HD Request # 11 | Decompressing data. | 2022-03-16 12:03:47.537
Socket (3) | CloseSocket call. | 2022-03-16 12:03:47.539
Historical data download thread signaled to stop. | 2022-03-16 12:03:47.539
HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBX21_FUT_CME | 2022-03-16 12:03:47.539
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:47.539
HD Request # 11 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:47.541
HD Request # 11 | Completion time: 0s | 2022-03-16 12:03:47.541
HD Request # 11 | Intraday data download complete for BBX21_FUT_CME. Unique request ID: 10 | 2022-03-16 12:03:47.541
Removing historical data download ID 10. | 2022-03-16 12:03:47.541
Real-time Intraday chart data file updates started for BBX21_FUT_CME | 2022-03-16 12:03:47.541
Intraday chart data file opened for BBX21_FUT_CME | 2022-03-16 12:03:47.541
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:47.541
Triggering next historical data download in queue. | 2022-03-16 12:03:47.541
Mapping BBZ21_FUT_CME to BBZ21. Service code: nymex | 2022-03-16 12:03:47.541
HD Request # 12 | Downloading Intraday chart data for BBZ21_FUT_CME to the file BBZ21_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:47.541
HD Request # 12 | Download start date-time: 2021-09-15 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:47.543
HD Request # 12 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:47.543
Socket (4) | Creating socket. | 2022-03-16 12:03:47.543
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 12:03:47.543
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:47.543
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:47.655
Socket (3) | Closed. | 2022-03-16 12:03:47.655
HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:47.776
HD Request # 12 | Sending historical data logon request message. | 2022-03-16 12:03:47.776
HD Request # 12 | Requesting Intraday data. Start date-time: 2021-09-15 00:00:00. Record interval: 0. Symbol: BBZ21 | 2022-03-16 12:03:47.896
HD Request # 12 | Decompressing data. | 2022-03-16 12:03:48.006
Socket (4) | CloseSocket call. | 2022-03-16 12:03:48.007
Historical data download thread signaled to stop. | 2022-03-16 12:03:48.007
HD Request # 12 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBZ21_FUT_CME | 2022-03-16 12:03:48.007
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:48.007
HD Request # 12 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:48.008
HD Request # 12 | Completion time: 1s | 2022-03-16 12:03:48.008
HD Request # 12 | Intraday data download complete for BBZ21_FUT_CME. Unique request ID: 11 | 2022-03-16 12:03:48.008
Removing historical data download ID 11. | 2022-03-16 12:03:48.008
Real-time Intraday chart data file updates started for BBZ21_FUT_CME | 2022-03-16 12:03:48.008
Intraday chart data file opened for BBZ21_FUT_CME | 2022-03-16 12:03:48.008
HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:48.008
Triggering next historical data download in queue. | 2022-03-16 12:03:48.008
Mapping BBF22_FUT_CME to BBF22. Service code: nymex | 2022-03-16 12:03:48.008
HD Request # 13 | Downloading Intraday chart data for BBF22_FUT_CME to the file BBF22_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:48.008
HD Request # 13 | Download start date-time: 2021-10-14 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:48.009
HD Request # 13 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:48.009
Socket (3) | Creating socket. | 2022-03-16 12:03:48.009
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:48.009
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:48.009
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 12:03:48.117
Socket (4) | Closed. | 2022-03-16 12:03:48.117
HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:48.250
HD Request # 13 | Sending historical data logon request message. | 2022-03-16 12:03:48.250
HD Request # 13 | Requesting Intraday data. Start date-time: 2021-10-14 00:00:00. Record interval: 0. Symbol: BBF22 | 2022-03-16 12:03:48.369
HD Request # 13 | Decompressing data. | 2022-03-16 12:03:48.487
Socket (3) | CloseSocket call. | 2022-03-16 12:03:48.487
Historical data download thread signaled to stop. | 2022-03-16 12:03:48.487
HD Request # 13 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBF22_FUT_CME | 2022-03-16 12:03:48.487
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:48.488
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:48.488
HD Request # 13 | Completion time: 0s | 2022-03-16 12:03:48.488
HD Request # 13 | Intraday data download complete for BBF22_FUT_CME. Unique request ID: 12 | 2022-03-16 12:03:48.488
Removing historical data download ID 12. | 2022-03-16 12:03:48.488
Real-time Intraday chart data file updates started for BBF22_FUT_CME | 2022-03-16 12:03:48.488
Intraday chart data file opened for BBF22_FUT_CME | 2022-03-16 12:03:48.488
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:48.488
Triggering next historical data download in queue. | 2022-03-16 12:03:48.488
Mapping BBG22_FUT_CME to BBG22. Service code: nymex | 2022-03-16 12:03:48.488
HD Request # 14 | Downloading Intraday chart data for BBG22_FUT_CME to the file BBG22_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:48.489
HD Request # 14 | Download start date-time: 2021-11-15 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:48.489
HD Request # 14 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:03:48.489
Socket (4) | Creating socket. | 2022-03-16 12:03:48.489
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 12:03:48.489
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:03:48.489
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:48.605
Socket (3) | Closed. | 2022-03-16 12:03:48.605
HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:48.735
HD Request # 14 | Sending historical data logon request message. | 2022-03-16 12:03:48.735
HD Request # 14 | Requesting Intraday data. Start date-time: 2021-11-15 00:00:00. Record interval: 0. Symbol: BBG22 | 2022-03-16 12:03:48.845
HD Request # 14 | Decompressing data. | 2022-03-16 12:03:48.956
Socket (4) | CloseSocket call. | 2022-03-16 12:03:48.958
Historical data download thread signaled to stop. | 2022-03-16 12:03:48.958
HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBG22_FUT_CME | 2022-03-16 12:03:48.958
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:48.958
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:48.960
HD Request # 14 | Completion time: 0s | 2022-03-16 12:03:48.960
HD Request # 14 | Intraday data download complete for BBG22_FUT_CME. Unique request ID: 13 | 2022-03-16 12:03:48.960
Removing historical data download ID 13. | 2022-03-16 12:03:48.960
Real-time Intraday chart data file updates started for BBG22_FUT_CME | 2022-03-16 12:03:48.960
Intraday chart data file opened for BBG22_FUT_CME | 2022-03-16 12:03:48.960
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:48.960
Triggering next historical data download in queue. | 2022-03-16 12:03:48.960
HD Request # 15 | Downloading Intraday chart data for BBH22_FUT_CME to the file BBH22_FUT_CME.scid. Service: nymex | 2022-03-16 12:03:48.960
HD Request # 15 | Download start date-time: 2021-12-16 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:03:48.961
HD Request # 15 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:03:48.962
Socket (3) | Creating socket. | 2022-03-16 12:03:48.962
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:03:48.962
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:03:48.962
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 12:03:49.068
Socket (4) | Closed. | 2022-03-16 12:03:49.068
HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-03-16 12:03:49.187
HD Request # 15 | Sending historical data logon request message. | 2022-03-16 12:03:49.187
HD Request # 15 | Requesting Intraday data. Start date-time: 2021-12-16 00:00:00. Record interval: 0. Symbol: BBH22 | 2022-03-16 12:03:49.297
HD Request # 15 | Decompressing data. | 2022-03-16 12:03:49.405
Socket (3) | CloseSocket call. | 2022-03-16 12:03:49.406
Historical data download thread signaled to stop. | 2022-03-16 12:03:49.406
HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBH22_FUT_CME | 2022-03-16 12:03:49.406
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:03:49.406
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 12:03:49.407
HD Request # 15 | Completion time: 1s | 2022-03-16 12:03:49.407
HD Request # 15 | Intraday data download complete for BBH22_FUT_CME. Unique request ID: 14 | 2022-03-16 12:03:49.407
Removing historical data download ID 14. | 2022-03-16 12:03:49.407
Real-time Intraday chart data file updates started for BBH22_FUT_CME | 2022-03-16 12:03:49.407
Intraday chart data file opened for BBH22_FUT_CME | 2022-03-16 12:03:49.407
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:03:49.407
Triggering next historical data download in queue. | 2022-03-16 12:03:49.407
No download requests in the queue to start downloads for. | 2022-03-16 12:03:49.407
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:03:49.515
Socket (3) | Closed. | 2022-03-16 12:03:49.515
BBH22_FUT_CME [CBV] 2000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-16 12:03:49.869
BBH22_FUT_CME [CBV] 2000 Volume #4 | Reloading chart. | 2022-03-16 12:03:49.871
BBH22_FUT_CME [CBV] 2000 Volume #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BBH22_FUT_CME.scid | 2022-03-16 12:03:51.357
BBH22_FUT_CME [CBV] 2000 Volume #4 | Reloading chart. | 2022-03-16 12:03:51.366
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2021-12-31. | 2022-03-16 12:03:51.410
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2022-03-16. | 2022-03-16 12:03:51.410
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-11-30. | 2022-03-16 12:03:51.420
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-12-30. | 2022-03-16 12:03:51.420
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-10-29. | 2022-03-16 12:03:51.428
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-11-29. | 2022-03-16 12:03:51.428
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-09-30. | 2022-03-16 12:03:51.436
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-10-28. | 2022-03-16 12:03:51.436
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-08-31. | 2022-03-16 12:03:51.443
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-09-29. | 2022-03-16 12:03:51.443
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-07-30. | 2022-03-16 12:03:51.450
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-08-30. | 2022-03-16 12:03:51.450
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-06-30. | 2022-03-16 12:03:51.457
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-07-29. | 2022-03-16 12:03:51.457
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-05-31. | 2022-03-16 12:03:51.464
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-06-29. | 2022-03-16 12:03:51.464
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-04-30. | 2022-03-16 12:03:51.470
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-05-28. | 2022-03-16 12:03:51.470
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-03-31. | 2022-03-16 12:03:51.476
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-04-29. | 2022-03-16 12:03:51.476
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-02-26. | 2022-03-16 12:03:51.484
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-03-30. | 2022-03-16 12:03:51.484
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-01-29. | 2022-03-16 12:03:51.490
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-02-25. | 2022-03-16 12:03:51.490
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2020-12-31. | 2022-03-16 12:03:51.496
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2021-01-28. | 2022-03-16 12:03:51.496
BBH22_FUT_CME [CBV] 2000 Volume #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BBH22_FUT_CME.scid | 2022-03-16 12:03:52.931
SC Data - All Services | Starting real-time market data updates for: BBH22_FUT_CME (BBH22). ID: 13 Service code: nymex | 2022-03-16 12:03:52.945
SC Data - All Services | Requesting security definition data for: BBH22_FUT_CME (BBH22). ID: 13 | 2022-03-16 12:03:52.945
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22_FUT_CME | 2022-03-16 12:03:53.060
Teton CME Order Routing | Received security definition for symbol BBH22_FUT_CME | 2022-03-16 12:03:53.060
SC Data - All Services | Real-time data for symbol BBH22_FUT_CME is currently unavailable. | 2022-03-16 12:03:53.071
SC Data - All Services | Received security definition for symbol BBH22_FUT_CME | 2022-03-16 12:03:53.071
Teton CME Order Routing | Starting real-time market data updates for: BZ. ID: 21 Service code: equities.us | 2022-03-16 12:03:53.761
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: BZ | 2022-03-16 12:03:53.761
Teton CME Order Routing | Requesting security definition data for: BZ. ID: 21 | 2022-03-16 12:03:53.761
Mapping BZH22_FUT_CME to BZH22. Service code: nymex | 2022-03-16 12:04:56.799
SC Data - All Services | Starting real-time market data updates for: BZH22_FUT_CME (BZH22). ID: 22 Service code: nymex | 2022-03-16 12:04:56.800
SC Data - All Services | Requesting security definition data for: BZH22_FUT_CME (BZH22). ID: 22 | 2022-03-16 12:04:56.800
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BZH22_FUT_CME | 2022-03-16 12:04:56.915
Teton CME Order Routing | Received security definition for symbol BZH22_FUT_CME | 2022-03-16 12:04:56.915
SC Data - All Services | Real-time data for symbol BZH22_FUT_CME is currently unavailable. | 2022-03-16 12:04:56.922
SC Data - All Services | Received security definition for symbol BZH22_FUT_CME | 2022-03-16 12:04:56.922
Enabling compression for file: C:\SierraChart\Data\BZH22_FUT_CME.scid. This may take a while. | 2022-03-16 12:05:55.697
File compression enabled. C:\SierraChart\Data\BZH22_FUT_CME.scid. CompressionState=0 | 2022-03-16 12:05:55.697
BZH22_FUT_CME/CLJ22-NYMEX Renko 6t #7 | Reloading chart. | 2022-03-16 12:05:55.698
BZH22_FUT_CME/CLJ22-NYMEX Renko 6t #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BZH22_FUT_CME.scid | 2022-03-16 12:05:55.707
Added historical Intraday data request for BZH22_FUT_CME to the queue. | 2022-03-16 12:05:56.209
Intraday data recording state for symbol BZH22_FUT_CME is set to download 'Pending'. | 2022-03-16 12:05:56.209
Triggering next historical data download in queue. | 2022-03-16 12:05:56.209
HD Request # 16 | Downloading Intraday chart data for BZH22_FUT_CME to the file BZH22_FUT_CME.scid. Service: nymex | 2022-03-16 12:05:56.209
HD Request # 16 | Download start date-time: 2021-12-13 12:05:56.000000. File last date-time: 00:00:00.000000 | 2022-03-16 12:05:56.210
HD Request # 16 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 12:05:56.210
Socket (3) | Creating socket. | 2022-03-16 12:05:56.210
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:05:56.210
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-03-16 12:05:56.210
HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-03-16 12:05:56.444
HD Request # 16 | Sending historical data logon request message. | 2022-03-16 12:05:56.444
HD Request # 16 | Requesting Intraday data. Start date-time: 2021-12-13 12:05:56. Record interval: 0. Symbol: BZH22 | 2022-03-16 12:05:57.011
HD Request # 16 | Decompressing data. | 2022-03-16 12:05:57.126
HD Request # 16 | Receiving Intraday data for BZH22_FUT_CME starting at 2021-12-13 12:07:10.231000 | 2022-03-16 12:05:57.475
HD Request # 16 | Timestamp of first Intraday data file record written: 2021-12-13 12:07:10.231000 | 2022-03-16 12:05:57.948
BZH22_FUT_CME[M]/CLJ22-NYMEX Renko 6t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:05:58.315
Socket (3) | CloseSocket call. | 2022-03-16 12:05:58.897
Historical data download thread signaled to stop. | 2022-03-16 12:05:58.898
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:05:58.898
HD Request # 16 | Received 302498 Intraday data records from 2021-12-13 12:07:10.231000 to 2022-01-31 19:22:11.705000 (49.3 days) and wrote 302498 records for BZH22_FUT_CME | 2022-03-16 12:05:58.898
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-01-31 19:22:11.705000 | 2022-03-16 12:05:58.905
HD Request # 16 | Completion time: 2s | 2022-03-16 12:05:58.906
HD Request # 16 | Intraday data download complete for BZH22_FUT_CME. Unique request ID: 16 | 2022-03-16 12:05:58.906
Removing historical data download ID 16. | 2022-03-16 12:05:58.906
Real-time Intraday chart data file updates started for BZH22_FUT_CME | 2022-03-16 12:05:58.906
Intraday chart data file opened for BZH22_FUT_CME | 2022-03-16 12:05:58.906
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:05:58.906
Triggering next historical data download in queue. | 2022-03-16 12:05:58.906
No download requests in the queue to start downloads for. | 2022-03-16 12:05:58.906
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:05:59.007
Socket (3) | Closed. | 2022-03-16 12:05:59.007
BZH22_FUT_CME Renko 6t #7 | Reloading chart. | 2022-03-16 12:07:05.271
BZH22_FUT_CME[M] Renko 6t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:07:23.541
BZH22_FUT_CME[M] Renko 6t #7 | Reloading chart. | 2022-03-16 12:08:37.695
BZH22_FUT_CME[M] Renko 6t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:08:54.835
BZH22_FUT_CME[M] Renko 6t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:09:06.476
BZH22_FUT_CME[M] Renko 6t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:09:15.626
BBH22_FUT_CME[M] Renko 6t #7 | Reloading chart. | 2022-03-16 12:12:05.042
BBH22_FUT_CME[M] Renko 6t #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BBH22_FUT_CME.scid | 2022-03-16 12:12:05.050
Saved Chartbook: G7FX_CL_FULL DECK_Jan2022.Cht. Time: 0.0101 seconds. | 2022-03-16 12:13:40.934
Unsubscribed from market depth data for CLJ22-NYMEX | 2022-03-16 12:13:44.072
ESM22_FUT_CME [CBV] 7500 Volume #1 | Reloading chart. | 2022-03-16 12:15:37.471
ESM22_FUT_CME [CBV] 7500 Volume #1 | Performing continuous chart historical Daily data download for symbol ESM22_FUT_CME starting at last date in file. | 2022-03-16 12:15:37.514
Added historical Daily data request for ESM22_FUT_CME to the queue. | 2022-03-16 12:15:37.514
Triggering next historical data download in queue. | 2022-03-16 12:15:37.514
ESM22_FUT_CME [CBV] 7500 Volume #1 | Waiting for historical downloads to complete with the IDs: 17, | 2022-03-16 12:15:37.662
ESM22_FUT_CME [CBV] #3 | Reloading chart. | 2022-03-16 12:15:37.745
ESM22_FUT_CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 17, | 2022-03-16 12:15:37.901
ESM22_FUT_CME [CBV] 5000 Volume #4 | Reloading chart. | 2022-03-16 12:15:38.294
ESM22_FUT_CME [CBV] 5000 Volume #4 | Waiting for historical downloads to complete with the IDs: 17, | 2022-03-16 12:15:38.459
ESM22_FUT_CME #6 | Reloading chart. | 2022-03-16 12:15:38.522
ESM22_FUT_CME Renko 5t #7 | Reloading chart. | 2022-03-16 12:15:38.598
Mapping ESM22_FUT_CME to ESM22. Service code: cme | 2022-03-16 12:15:38.641
SC Data - All Services | Starting real-time market data updates for: ESM22_FUT_CME (ESM22). ID: 23 Service code: cme | 2022-03-16 12:15:38.641
SC Data - All Services | Requesting security definition data for: ESM22_FUT_CME (ESM22). ID: 23 | 2022-03-16 12:15:38.641
Mapping ESU22_FUT_CME to ESU22. Service code: cme | 2022-03-16 12:15:38.641
SC Data - All Services | Starting real-time market data updates for: ESU22_FUT_CME (ESU22). ID: 24 Service code: cme | 2022-03-16 12:15:38.641
SC Data - All Services | Requesting security definition data for: ESU22_FUT_CME (ESU22). ID: 24 | 2022-03-16 12:15:38.641
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-03-16 12:15:38.641
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 25 Service code: cme | 2022-03-16 12:15:38.642
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 25 | 2022-03-16 12:15:38.642
HD Request # 17 | Downloading Historical Daily chart data for ESM22_FUT_CME. Starting date: 2022-03-11. Service: sc_futures_direct.dtc.trading | 2022-03-16 12:15:38.665
ESM22_FUT_CME #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:15:38.703
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM22_FUT_CME | 2022-03-16 12:15:38.782
Teton CME Order Routing | Received security definition for symbol ESM22_FUT_CME | 2022-03-16 12:15:38.782
SC Data - All Services | Received security definition for symbol ESM22_FUT_CME | 2022-03-16 12:15:38.782
SC Data - All Services | Received security definition for symbol ESU22_FUT_CME | 2022-03-16 12:15:38.782
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-03-16 12:15:38.783
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU22_FUT_CME | 2022-03-16 12:15:38.783
Teton CME Order Routing | Received security definition for symbol ESU22_FUT_CME | 2022-03-16 12:15:38.783
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-03-16 12:15:38.783
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-03-16 12:15:38.783
Added historical Intraday data request for ESM22_FUT_CME to the queue. | 2022-03-16 12:15:38.887
Intraday data recording state for symbol ESM22_FUT_CME is set to download 'Pending'. | 2022-03-16 12:15:38.887
Triggering next historical data download in queue. | 2022-03-16 12:15:38.887
Delaying start of download for ESM22_FUT_CME | 2022-03-16 12:15:38.894
HD Request # 17 | Requesting historical Daily data for ESM22 starting at 2022-03-10. SC External HD service. | 2022-03-16 12:15:39.096
Requesting market depth updates for: ESM22_FUT_CME if supported. | 2022-03-16 12:15:39.175
SC Data - All Services | Clearing market depth for ESM22_FUT_CME | 2022-03-16 12:15:39.284
HD Request # 17 | Receiving historical Daily data for ESM22_FUT_CME starting at 2022-03-11 | 2022-03-16 12:15:39.331
HD Request # 17 | Writing historical Daily data to the file ESM22_FUT_CME.dly | 2022-03-16 12:15:39.332
HD Request # 17 | Bytes received: 244 | 2022-03-16 12:15:39.336
HD Request # 17 | Received 4 Daily data records from 2022-03-11 00:00:00 to 2022-03-15 00:00:00 (5.0 days) and wrote 3 records for ESM22_FUT_CME | 2022-03-16 12:15:39.336
HD Request # 17 | Completion time: 1s | 2022-03-16 12:15:39.336
HD Request # 17 | Daily data download complete for ESM22_FUT_CME. Unique request ID: 17 | 2022-03-16 12:15:39.336
Removing historical data download ID 17. | 2022-03-16 12:15:39.336
Triggering next historical data download in queue. | 2022-03-16 12:15:39.336
No download requests in the queue to start downloads for. | 2022-03-16 12:15:39.336
ESM22_FUT_CME [CBV] 7500 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-16 12:15:39.469
ESM22_FUT_CME [CBV] 7500 Volume #1 | Reloading chart. | 2022-03-16 12:15:39.470
ESM22_FUT_CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-16 12:15:39.751
ESM22_FUT_CME [CBV] #3 | Reloading chart. | 2022-03-16 12:15:39.751
ESM22_FUT_CME [CBV] 5000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-16 12:15:40.006
ESM22_FUT_CME [CBV] 5000 Volume #4 | Reloading chart. | 2022-03-16 12:15:40.012
ESM22_FUT_CME [CBV] 7500 Volume #1 | Reloading chart. | 2022-03-16 12:15:40.295
ESM22_FUT_CME [CBV] #3 | Reloading chart. | 2022-03-16 12:15:40.994
ESM22_FUT_CME [CBV] 5000 Volume #4 | Reloading chart. | 2022-03-16 12:15:41.673
HD Request # 18 | Downloading Intraday chart data for ESM22_FUT_CME to the file ESM22_FUT_CME.scid. Service: cme | 2022-03-16 12:15:43.483
HD Request # 18 | Download start date-time: 2022-03-16 10:29:30.000000. File last date-time: 2022-03-16 10:29:30.769000 | 2022-03-16 12:15:43.484
HD Request # 18 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 12:15:43.484
Socket (3) | Creating socket. | 2022-03-16 12:15:43.484
Socket (3) | New receive buffer size: 5242880 | 2022-03-16 12:15:43.485
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-16 12:15:43.485
HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-03-16 12:15:43.706
HD Request # 18 | Sending historical data logon request message. | 2022-03-16 12:15:43.706
HD Request # 18 | Requesting Intraday data. Start date-time: 2022-03-16 10:29:30. Record interval: 0. Symbol: ESM22 | 2022-03-16 12:15:44.267
HD Request # 18 | Decompressing data. | 2022-03-16 12:15:44.372
HD Request # 18 | Receiving Intraday data for ESM22_FUT_CME starting at 2022-03-16 10:29:30.769000 | 2022-03-16 12:15:44.610
Socket (3) | CloseSocket call. | 2022-03-16 12:15:45.042
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-16 12:15:45.042
Historical data download thread signaled to stop. | 2022-03-16 12:15:45.042
HD Request # 18 | Timestamp of first Intraday data file record written: 2022-03-16 10:29:32.475000 | 2022-03-16 12:15:45.043
HD Request # 18 | Received 30032 Intraday data records from 2022-03-16 10:29:30.769000 to 2022-03-16 12:15:40.220001 (106.2 minutes) and wrote 30031 records for ESM22_FUT_CME | 2022-03-16 12:15:45.044
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-03-16 12:15:40.220001 | 2022-03-16 12:15:45.063
Added 2 Time and Sales records to Intraday data file for ESM22_FUT_CME after download. | 2022-03-16 12:15:45.068
HD Request # 18 | Completion time: 2s | 2022-03-16 12:15:45.068
HD Request # 18 | Intraday data download complete for ESM22_FUT_CME. Unique request ID: 18 | 2022-03-16 12:15:45.068
Removing historical data download ID 18. | 2022-03-16 12:15:45.068
Real-time Intraday chart data file updates started for ESM22_FUT_CME | 2022-03-16 12:15:45.068
Intraday chart data file opened for ESM22_FUT_CME | 2022-03-16 12:15:45.068
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-03-16 12:15:45.068
Triggering next historical data download in queue. | 2022-03-16 12:15:45.068
No download requests in the queue to start downloads for. | 2022-03-16 12:15:45.068
Socket (3) | Socket gracefully closed by remote side. | 2022-03-16 12:15:45.152
Socket (3) | Closed. | 2022-03-16 12:15:45.152
Opened cached Intraday file: C:\SierraChart\Data\ESM22_FUT_CME.scid. Thread ID: 9936 | 2022-03-16 12:15:49.295
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:15:49.948
ESM22_FUT_CME [CBV][M] 7500 Volume #1 | Reloading chart. | 2022-03-16 12:16:20.110
ESM22_FUT_CME [CBV][M] 7500 Volume #1 | Reloading chart. | 2022-03-16 12:16:46.616
ESM22_FUT_CME [CBV][M] #3 | Reloading chart. | 2022-03-16 12:17:37.193
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | Reloading chart. | 2022-03-16 12:18:38.971
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 12:18:51.090
ESM22_FUT_CME[M] Renko 5t #7 | Reloading chart. | 2022-03-16 12:19:44.603
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 13:20:00.499
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 13:20:04.973
ESM22_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 2022-03-01 23:00:00 | 2022-03-16 13:21:37.292
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 2020-11-25 01:00:35 | 2022-03-16 13:21:37.609
ESM22_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 13:21:54.178
ESM22_FUT_CME [CBV][M] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 13:21:54.226
CLJ22-NYMEX [CBV] #2 | Reloading chart. | 2022-03-16 13:24:44.324
CLJ22-NYMEX [CBV] #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 13:24:44.324
CLJ22-NYMEX [CBV] #2 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 13:24:44.324
CLJ22-NYMEX [CBV] 2000 Volume #3 | Reloading chart. | 2022-03-16 13:24:44.421
CLJ22-NYMEX [CBV] 2000 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 13:24:44.421
CLJ22-NYMEX [CBV] 2000 Volume #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 13:24:44.421
BBH22_FUT_CME [CBV] 2000 Volume #4 | Reloading chart. | 2022-03-16 13:24:44.529
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2021-12-31. | 2022-03-16 13:24:44.629
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH22_FUT_CME.dly has a volume of 0 at 2022-03-16. | 2022-03-16 13:24:44.629
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-11-30. | 2022-03-16 13:24:44.646
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBG22_FUT_CME.dly has a volume of 0 at 2021-12-30. | 2022-03-16 13:24:44.646
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-10-29. | 2022-03-16 13:24:44.661
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBF22_FUT_CME.dly has a volume of 0 at 2021-11-29. | 2022-03-16 13:24:44.661
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-09-30. | 2022-03-16 13:24:44.675
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBZ21_FUT_CME.dly has a volume of 0 at 2021-10-28. | 2022-03-16 13:24:44.675
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-08-31. | 2022-03-16 13:24:44.690
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBX21_FUT_CME.dly has a volume of 0 at 2021-09-29. | 2022-03-16 13:24:44.690
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-07-30. | 2022-03-16 13:24:44.708
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBV21_FUT_CME.dly has a volume of 0 at 2021-08-30. | 2022-03-16 13:24:44.708
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-06-30. | 2022-03-16 13:24:44.722
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBU21_FUT_CME.dly has a volume of 0 at 2021-07-29. | 2022-03-16 13:24:44.722
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-05-31. | 2022-03-16 13:24:44.735
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBQ21_FUT_CME.dly has a volume of 0 at 2021-06-29. | 2022-03-16 13:24:44.735
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-04-30. | 2022-03-16 13:24:44.747
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBN21_FUT_CME.dly has a volume of 0 at 2021-05-28. | 2022-03-16 13:24:44.747
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-03-31. | 2022-03-16 13:24:44.761
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBM21_FUT_CME.dly has a volume of 0 at 2021-04-29. | 2022-03-16 13:24:44.761
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-02-26. | 2022-03-16 13:24:44.774
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBK21_FUT_CME.dly has a volume of 0 at 2021-03-30. | 2022-03-16 13:24:44.774
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-01-29. | 2022-03-16 13:24:44.785
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBJ21_FUT_CME.dly has a volume of 0 at 2021-02-25. | 2022-03-16 13:24:44.785
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2020-12-31. | 2022-03-16 13:24:44.796
BBH22_FUT_CME [CBV] 2000 Volume #4 | File BBH21_FUT_CME.dly has a volume of 0 at 2021-01-28. | 2022-03-16 13:24:44.796
CLJ22-NYMEX #5 | Reloading chart. | 2022-03-16 13:24:46.518
CLJ22-NYMEX [CBV] 5 Min #6 | Reloading chart. | 2022-03-16 13:24:46.637
CLJ22-NYMEX [CBV] 5 Min #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-03-16 13:24:46.637
CLJ22-NYMEX [CBV] 5 Min #6 | There are no continuous futures contract symbols. Loading data normally. | 2022-03-16 13:24:46.637
BBH22_FUT_CME Renko 6t #7 | Reloading chart. | 2022-03-16 13:24:46.745
CLJ22-NYMEX [CBV-D] #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 13:24:46.834
CLJ22-NYMEX [CBV-D] 2000 Volume #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 13:24:46.838
BBH22_FUT_CME [CBV] 2000 Volume #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BBH22_FUT_CME.scid | 2022-03-16 13:24:46.850
CLJ22-NYMEX #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-16 13:24:46.886
CLJ22-NYMEX [CBV-D] 5 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLJ22-NYMEX.scid | 2022-03-16 13:24:46.898
BBH22_FUT_CME Renko 6t #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BBH22_FUT_CME.scid | 2022-03-16 13:24:46.905
Requesting market depth updates for: CLJ22-NYMEX if supported. | 2022-03-16 13:24:47.004
Separate subscription for market depth updates not supported. CLJ22-NYMEX | 2022-03-16 13:24:47.004
File >> Disconnect selected. | 2022-03-16 13:25:38.459
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-03-16 13:25:38.475
DTC Client socket (1) | CloseSocket call. | 2022-03-16 13:25:38.475
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-03-16 13:25:38.475
DTC Client socket (1) | Max send buffer size during socket life: 354 | 2022-03-16 13:25:38.475
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-16 13:25:38.475
SC Data - All Services | Waiting for socket receive thread to end | 2022-03-16 13:25:38.476
DTC Client socket (2) | CloseSocket call. | 2022-03-16 13:25:38.476
DTC Client socket (2) | Max send buffers used during socket life: 3 | 2022-03-16 13:25:38.476
DTC Client socket (2) | Max send buffer size during socket life: 504 | 2022-03-16 13:25:38.476
SC Data - All Services | Disconnected from the server. | 2022-03-16 13:25:38.476
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-16 13:25:38.476
Teton CME Order Routing | Disconnected. | 2022-03-16 13:25:38.476
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-03-16 13:25:38.589
DTC Client socket (1) | Closed. | 2022-03-16 13:25:38.589
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-16 13:25:51.676
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-16 13:25:51.729
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-16 13:25:51.730
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-16 13:25:51.730
Teton CME Order Routing | Network connection to server complete. | 2022-03-16 13:25:51.851
Teton CME Order Routing | Starting socket receive thread. | 2022-03-16 13:25:51.851
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-03-16 13:25:51.851
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-03-16 13:25:52.188
Teton CME Order Routing | Sending logon request message. | 2022-03-16 13:25:52.188
Teton CME Order Routing | Received logon response. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Server Name: SC DTC Server. Build=41200. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-03-16 13:25:52.764
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Trading is supported. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Order cancel and replace is supported. | 2022-03-16 13:25:52.764
Teton CME Order Routing | OCO Orders supported. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Bracket Orders supported. | 2022-03-16 13:25:52.764
Teton CME Order Routing | Connected to server complete. | 2022-03-16 13:25:52.764
Triggering next historical data download in queue. | 2022-03-16 13:25:52.769
Triggering next historical data download in queue. | 2022-03-16 13:25:52.770
Updated verified funded futures trading account ending date to: 2022-04-15 13:25:52 | 2022-03-16 13:25:52.770
No download requests in the queue to start downloads for. | 2022-03-16 13:25:52.807
Using symbol data fast lookup vector | 2022-03-16 13:25:52.808
Teton CME Order Routing | Starting real-time market data updates for: CLJ22-NYMEX. ID: 1 | 2022-03-16 13:25:52.808
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: CLJ22-NYMEX | 2022-03-16 13:25:52.808
Teton CME Order Routing | Requesting security definition data for: CLJ22-NYMEX. ID: 1 | 2022-03-16 13:25:52.808
No historical data client is currently set to download historical Intraday data for CLJ22-NYMEX. | 2022-03-16 13:25:52.808
Real-time Intraday chart data file updates started for CLJ22-NYMEX | 2022-03-16 13:25:52.808
Intraday chart data file opened for CLJ22-NYMEX | 2022-03-16 13:25:52.808
Mapping ESM22_FUT_CME to ESM22. Service code: cme | 2022-03-16 13:25:52.814
SC Data - All Services | Starting real-time market data updates for: ESM22_FUT_CME (ESM22). ID: 2 Service code: cme | 2022-03-16 13:25:52.814
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-03-16 13:25:52.814
SC Data - All Services | Requesting security definition data for: ESM22_FUT_CME (ESM22). ID: 2 | 2022-03-16 13:25:52.814
Added historical Intraday data request for ESM22_FUT_CME to the queue. | 2022-03-16 13:25:52.814
Intraday data recording state for symbol ESM22_FUT_CME is set to download 'Pending'. | 2022-03-16 13:25:52.814
Triggering next historical data download in queue. | 2022-03-16 13:25:52.814
Delaying start of download for ESM22_FUT_CME | 2022-03-16 13:25:52.815
DTC Client socket (3) | Creating socket. | 2022-03-16 13:25:52.875
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-16 13:25:52.875
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-03-16 13:25:52.875
Updated verified funded futures trading account ending date to: 2022-04-15 13:25:52 | 2022-03-16 13:25:52.918
Teton CME Order Routing | Received security definition for symbol CLJ22-NYMEX | 2022-03-16 13:25:52.919
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM22_FUT_CME | 2022-03-16 13:25:52.925
Teton CME Order Routing | Received security definition for symbol ESM22_FUT_CME | 2022-03-16 13:25:52.925
SC Data - All Services | Network connection to server complete. | 2022-03-16 13:25:52.990
SC Data - All Services | Starting socket receive thread. | 2022-03-16 13:25:52.990
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-16 13:25:52.990
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-03-16 13:25:53.007
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 3 Service code: cme | 2022-03-16 13:25:53.007
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 3 | 2022-03-16 13:25:53.007
Mapping ESU22_FUT_CME to ESU22. Service code: cme | 2022-03-16 13:25:53.007
SC Data - All Services | Starting real-time market data updates for: ESU22_FUT_CME (ESU22). ID: 4 Service code: cme | 2022-03-16 13:25:53.007
SC Data - All Services | Requesting security definition data for: ESU22_FUT_CME (ESU22). ID: 4 | 2022-03-16 13:25:53.007
Mapping BBH22_FUT_CME to BBH22. Service code: nymex | 2022-03-16 13:25:53.115
SC Data - All Services | Starting real-time market data updates for: BBH22_FUT_CME (BBH22). ID: 5 Service code: nymex | 2022-03-16 13:25:53.115
SC Data - All Services | Requesting security definition data for: BBH22_FUT_CME (BBH22). ID: 5 | 2022-03-16 13:25:53.115
Added historical Intraday data request for BBH22_FUT_CME to the queue. | 2022-03-16 13:25:53.115
Intraday data recording state for symbol BBH22_FUT_CME is set to download 'Pending'. | 2022-03-16 13:25:53.115
Triggering next historical data download in queue. | 2022-03-16 13:25:53.115
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-03-16 13:25:53.119
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-03-16 13:25:53.119
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-03-16 13:25:53.129
SC Data - All Services | Sending logon request message. | 2022-03-16 13:25:53.129
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU22_FUT_CME | 2022-03-16 13:25:53.181
Teton CME Order Routing | Received security definition for symbol ESU22_FUT_CME | 2022-03-16 13:25:53.181
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22_FUT_CME | 2022-03-16 13:25:53.228
Teton CME Order Routing | Received security definition for symbol BBH22_FUT_CME | 2022-03-16 13:25:53.228
Mapping BBK22_FUT_CME to BBK22. Service code: nymex | 2022-03-16 13:25:53.377
SC Data - All Services | Starting real-time market data updates for: BBK22_FUT_CME (BBK22). ID: 6 Service code: nymex | 2022-03-16 13:25:53.378
SC Data - All Services | Requesting security definition data for: BBK22_FUT_CME (BBK22). ID: 6 | 2022-03-16 13:25:53.378
Mapping BBM22_FUT_CME to BBM22. Service code: nymex | 2022-03-16 13:25:53.378
SC Data - All Services | Starting real-time market data updates for: BBM22_FUT_CME (BBM22). ID: 7 Service code: nymex | 2022-03-16 13:25:53.378
SC Data - All Services | Requesting security definition data for: BBM22_FUT_CME (BBM22). ID: 7 | 2022-03-16 13:25:53.378
Mapping BBN22_FUT_CME to BBN22. Service code: nymex | 2022-03-16 13:25:53.378
SC Data - All Services | Starting real-time market data updates for: BBN22_FUT_CME (BBN22). ID: 8 Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Requesting security definition data for: BBN22_FUT_CME (BBN22). ID: 8 | 2022-03-16 13:25:53.379
Mapping BBQ22_FUT_CME to BBQ22. Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Starting real-time market data updates for: BBQ22_FUT_CME (BBQ22). ID: 9 Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Requesting security definition data for: BBQ22_FUT_CME (BBQ22). ID: 9 | 2022-03-16 13:25:53.379
Mapping BBU22_FUT_CME to BBU22. Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Starting real-time market data updates for: BBU22_FUT_CME (BBU22). ID: 10 Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Requesting security definition data for: BBU22_FUT_CME (BBU22). ID: 10 | 2022-03-16 13:25:53.379
Mapping BBV22_FUT_CME to BBV22. Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Starting real-time market data updates for: BBV22_FUT_CME (BBV22). ID: 11 Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Requesting security definition data for: BBV22_FUT_CME (BBV22). ID: 11 | 2022-03-16 13:25:53.379
Mapping BBX22_FUT_CME to BBX22. Service code: nymex | 2022-03-16 13:25:53.379
SC Data - All Services | Starting real-time market data updates for: BBX22_FUT_CME (BBX22). ID: 12 Service code: nymex | 2022-03-16 13:25:53.380
SC Data - All Services | Requesting security definition data for: BBX22_FUT_CME (BBX22). ID: 12 | 2022-03-16 13:25:53.380
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBK22_FUT_CME | 2022-03-16 13:25:53.490
Teton CME Order Routing | Received security definition for symbol BBK22_FUT_CME | 2022-03-16 13:25:53.490
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBM22_FUT_CME | 2022-03-16 13:25:53.490
Teton CME Order Routing | Received security definition for symbol BBM22_FUT_CME | 2022-03-16 13:25:53.490
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBN22_FUT_CME | 2022-03-16 13:25:53.490
Teton CME Order Routing | Received security definition for symbol BBN22_FUT_CME | 2022-03-16 13:25:53.490
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBQ22_FUT_CME | 2022-03-16 13:25:53.629
Teton CME Order Routing | Received security definition for symbol BBQ22_FUT_CME | 2022-03-16 13:25:53.629
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBU22_FUT_CME | 2022-03-16 13:25:53.629
Teton CME Order Routing | Received security definition for symbol BBU22_FUT_CME | 2022-03-16 13:25:53.629
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBV22_FUT_CME | 2022-03-16 13:25:53.629
Teton CME Order Routing | Received security definition for symbol BBV22_FUT_CME | 2022-03-16 13:25:53.629
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBX22_FUT_CME | 2022-03-16 13:25:53.629
Teton CME Order Routing | Received security definition for symbol BBX22_FUT_CME | 2022-03-16 13:25:53.629
SC Data - All Services | Received logon response. | 2022-03-16 13:25:53.994
SC Data - All Services | Server Name: SC Realtime Server. | 2022-03-16 13:25:53.994
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-03-16 13:25:53.994
SC Data - All Services | Successfully connected. | 2022-03-16 13:25:53.994
SC Data - All Services | Trading is not supported. | 2022-03-16 13:25:53.994
SC Data - All Services | Restarting real-time data updates for symbol: BBH22_FUT_CME -> BBH22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBK22_FUT_CME -> BBK22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBM22_FUT_CME -> BBM22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBN22_FUT_CME -> BBN22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBQ22_FUT_CME -> BBQ22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBU22_FUT_CME -> BBU22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBV22_FUT_CME -> BBV22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: BBX22_FUT_CME -> BBX22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: ESM22_FUT_CME -> ESM22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: ESU22_FUT_CME -> ESU22 | 2022-03-16 13:25:53.995
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22 | 2022-03-16 13:25:53.995
SC Data - All Services | Real-time data for symbol BBH22_FUT_CME is currently unavailable. | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBH22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBK22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBM22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBN22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBQ22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBU22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBV22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol BBX22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol ESM22_FUT_CME | 2022-03-16 13:25:54.213
SC Data - All Services | Received security definition for symbol ESU22_FUT_CME | 2022-03-16 13:25:54.214
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-03-16 13:25:54.214
Requesting market depth updates for: CLJ22-NYMEX if supported. | 2022-03-16 13:25:57.766
Separate subscription for market depth updates not supported. CLJ22-NYMEX | 2022-03-16 13:25:57.766
Requesting market depth updates for: ESM22_FUT_CME if supported. | 2022-03-16 13:25:57.767
SC Data - All Services | Clearing market depth for ESM22_FUT_CME | 2022-03-16 13:25:57.960
HD Request # 19 | Downloading Intraday chart data for ESM22_FUT_CME to the file ESM22_FUT_CME.scid. Service: cme | 2022-03-16 13:25:59.975
HD Request # 19 | Download start date-time: 2022-03-16 13:25:38.000000. File last date-time: 2022-03-16 13:25:38.207002 | 2022-03-16 13:25:59.977
HD Request # 19 | Using server: ds23.sierracharts.com port 10149 | 2022-03-16 13:25:59.978
Socket (4) | Creating socket. | 2022-03-16 13:25:59.980
Socket (4) | New receive buffer size: 5242880 | 2022-03-16 13:25:59.980
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-16 13:25:59.980
HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-03-16 13:26:00.199
HD Request # 19 | Sending historical data logon request message. | 2022-03-16 13:26:00.199
HD Request # 19 | Requesting Intraday data. Start date-time: 2022-03-16 13:25:38. Record interval: 0. Symbol: ESM22 | 2022-03-16 13:26:00.796
HD Request # 19 | Decompressing data. | 2022-03-16 13:26:00.902
HD Request # 19 | Receiving Intraday data for ESM22_FUT_CME starting at 2022-03-16 13:25:38.030000 | 2022-03-16 13:26:00.903
Socket (4) | CloseSocket call. | 2022-03-16 13:26:00.903
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-16 13:26:00.904
Historical data download thread signaled to stop. | 2022-03-16 13:26:00.904
HD Request # 19 | Timestamp of first Intraday data file record written: 2022-03-16 13:25:40.056000 | 2022-03-16 13:26:00.904
HD Request # 19 | Received 139 Intraday data records from 2022-03-16 13:25:38.030000 to 2022-03-16 13:25:57.449002 (19.4 seconds) and wrote 119 records for ESM22_FUT_CME | 2022-03-16 13:26:00.904
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-03-16 13:25:57.449002 | 2022-03-16 13:26:00.913
Added 30 Time and Sales records to Intraday data file for ESM22_FUT_CME after download. | 2022-03-16 13:26:00.914
HD Request # 19 | Completion time: 1s | 2022-03-16 13:26:00.914
HD Request # 19 | Intraday data download complete for ESM22_FUT_CME. Unique request ID: 19 | 2022-03-16 13:26:00.914
Removing historical data download ID 19. | 2022-03-16 13:26:00.914
Real-time Intraday chart data file updates started for ESM22_FUT_CME | 2022-03-16 13:26:00.914
Intraday chart data file opened for ESM22_FUT_CME | 2022-03-16 13:26:00.914
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-03-16 13:26:00.914
Triggering next historical data download in queue. | 2022-03-16 13:26:00.914
HD Request # 20 | Downloading Intraday chart data for BBH22_FUT_CME to the file BBH22_FUT_CME.scid. Service: nymex | 2022-03-16 13:26:00.914
HD Request # 20 | Download start date-time: 2021-12-13 13:26:00.000000. File last date-time: 00:00:00.000000 | 2022-03-16 13:26:00.915
HD Request # 20 | Using server: ds21.sierracharts.com port 10150 | 2022-03-16 13:26:00.915
Socket (6) | Creating socket. | 2022-03-16 13:26:00.916
Socket (6) | New receive buffer size: 5242880 | 2022-03-16 13:26:00.916
Socket (6) | Connecting to IP: 216.1.90.129. | 2022-03-16 13:26:00.916
Socket (4) | Socket gracefully closed by remote side. | 2022-03-16 13:26:01.009
Socket (4) | Closed. | 2022-03-16 13:26:01.009
HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-03-16 13:26:01.148
HD Request # 20 | Sending historical data logon request message. | 2022-03-16 13:26:01.148
HD Request # 20 | Requesting Intraday data. Start date-time: 2021-12-13 13:26:00. Record interval: 0. Symbol: BBH22 | 2022-03-16 13:26:01.716
HD Request # 20 | Decompressing data. | 2022-03-16 13:26:01.838
Socket (6) | CloseSocket call. | 2022-03-16 13:26:01.839
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-03-16 13:26:01.839
Historical data download thread signaled to stop. | 2022-03-16 13:26:01.864
HD Request # 20 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BBH22_FUT_CME | 2022-03-16 13:26:01.864
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-03-16 13:26:01.864
HD Request # 20 | Completion time: 1s | 2022-03-16 13:26:01.864
HD Request # 20 | Intraday data download complete for BBH22_FUT_CME. Unique request ID: 20 | 2022-03-16 13:26:01.864
Removing historical data download ID 20. | 2022-03-16 13:26:01.864
Real-time Intraday chart data file updates started for BBH22_FUT_CME | 2022-03-16 13:26:01.864
Intraday chart data file opened for BBH22_FUT_CME | 2022-03-16 13:26:01.864
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-03-16 13:26:01.864
Triggering next historical data download in queue. | 2022-03-16 13:26:01.864
No download requests in the queue to start downloads for. | 2022-03-16 13:26:01.864
Socket (6) | Socket gracefully closed by remote side. | 2022-03-16 13:26:01.950
Socket (6) | Closed. | 2022-03-16 13:26:01.950
Opened cached Intraday file: C:\SierraChart\Data\ESM22_FUT_CME.scid. Thread ID: 9936 | 2022-03-16 13:26:03.293
imageCL.PNG / V - Attached On 2022-03-16 13:30:31 UTC - Size: 19.71 KB - 132 views
[2022-03-16 13:44:36]
This contract is expired:
And also BB has no volume. Check with the CME. So there is definitely nothing wrong.
If you have further questions about particular contracts check with the CME.
Date Time Of Last Edit: 2022-03-16 13:44:56
