Date/Time: Mon, 10 Mar 2025 02:38:40 +0000
EURO STOXX 50 (FESX) - tick change from 21 March 2022
View Count: 673
[2022-03-16 08:26:35] |
User365411 - Posts: 192 |
reminder for FESX traders and SC staff The Management Board of Eurex Deutschland decided to increase the minimum price change (tick) in outright contracts in EURO STOXX® 50 Index Futures (FESX) with effect from 21 March 2022. The new tick will be 1.0 index points (currently: 0.5 index points). The tick value will increase from EUR 5 to EUR 10. https://www.eurex.com/ex-en/find/circulars/circular-2919346 |
[2022-03-16 13:58:41] |
Thank you. We will make this change on the Sunday before. Monday morning do the following: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will also need to update this Tick Size within the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
