Date/Time: Sun, 28 Jun 2026 11:01:02 +0000
[Programming Help] - User Contributed User Contributed studies ddll.v2308 GannSwing
View Count: 919
[2022-03-16 02:29:18]
User793846 - Posts: 4
A few years back I worked with the User Contributed User Contributed studies ddll.v2308 indicator ""GannSwing""
At that time i was able to pull up that studies code and make and make a small change to the indicator.
Now that DLL is compiled and does not allow this.
Is there any way you can provide me with the original since it was donated?
I would like to make a small change and then compile and add it as new custom i run??
Your help would be greatly appreciated.
Jim L
[2022-03-16 13:55:18]
John - SC Support - Posts: 46920
We do not have the GannSwing code anymore that is used for the User Contributed Studies.
But the code for the Sierra Chart study named Gann Swing Oscillator is available in the file studies4.cpp located in the ACS_Source folder under your main Sierra Chart installation. We do not know if this can help you, but wanted to point it out in case it can.
[2022-03-20 03:12:44]
John,
I appreciate your response. Just wondered since the gan swing is still available in the second user contributed studies dll and it is compiled on your end is there a way to get at it? I thought you might be compiling since it is still in the system?
If not do you have the contributors information so, I could reach out to that person directly''
Thank you for help
Jim
Date Time Of Last Edit: 2022-03-20 03:13:41
