Date/Time: Mon, 10 Mar 2025 03:08:53 +0000
Plotting a vertical line every X bars
View Count: 684
[2022-03-16 00:51:19]
User540504 - Posts: 15
I want to plot a vertical line every x number of calendar days. The Time Line indicator works beautifully for intraday applications, but I need lines across weeks of time. The vertical grid in the chart menu is exactly what I want, allowing me to specify the exact amount of days, however I need to be able to anchor it from a specific date - then and only then do I need the specified count to begin. Is this possible with the vertical grid or another indicator?
[2022-03-16 13:06:11]
This is supported. Refer to:
Chart Menu: Vertical Grid (Chart menu)
You can then control the starting date, with this setting:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo
