Date/Time: Mon, 10 Mar 2025 07:12:17 +0000
Historical Data Date Range
View Count: 649
[2022-03-15 22:16:04]
User733502 - Posts: 46
Hello SC,
I'm using the SC Data service and am looking to load more historical daily data.
How can I do this or edit the Date Range period?
Appreciate the support!
imagehistorical data settings.png / V - Attached On 2022-03-15 22:09:53 UTC - Size: 163.28 KB - 150 views
[2022-03-16 00:12:13]
John - SC Support - Posts: 38516
Refer to the following and the section after it:
No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data: 6.4: Missing Data in a Historical Chart Due to the Days to Load Setting to Low
[2022-03-17 22:33:00]
Hi SC,
Thank you for the response.
This is not the issue.
My DAYS TO LOAD setting is at 3000 and I'm only able to view and download DAILY OHLC data back to 2020-12-27.
SC DATA Markets:
ETHUSDT-BINANCE
BTCUSDT-BINANCE
[2022-03-18 14:08:03]
That is all the data we have for those instruments.
[2022-03-18 16:42:06]
Ok
Will the data continue to build from what you have or will you drop the last date when you add the new?
[2022-03-18 18:07:28]
It will continue to build.
