Date/Time: Mon, 10 Mar 2025 02:04:31 +0000
Continuous Futures Contract
View Count: 603
[2022-03-15 19:08:28]
nico.bremond1982 - Posts: 2
I have a problem with the "Continuous Futures Contract" fonction in the chart settings. Before today I could load the backup for the futures contract with this function for all the contract (Eurex, CME, etc.) but since today I can't. It only load the current contract without the backup even I choose any Continuous contract option. It just works for the Eurobund.
Could you help me with this problem please?
For your information I have the current version of Sierrachart.
Thanks in advance,
Nicolas B
[2022-03-15 23:28:00]
John - SC Support - Posts: 38516
Please give us one example of the issue you are seeing and tell us what the Continuous Futures Contract setting is set to, and how many days you have set to load in your chart. Also please get us a screenshot of the chart by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
[2022-03-16 10:19:09]
As you can see on the both image attached, I try to load 600 days historical data and the date stop on the 2021-3-19. If I try to delete and reload the data, the software take 10 long minutes to reload exactly the same thing. I don't think I have change any settings but it could be. I have this problem for all the symbol unless FGBL.
imageUploadImage.png / V - Attached On 2022-03-16 10:12:37 UTC - Size: 148.96 KB - 139 views
imageUploadImage.png / V - Attached On 2022-03-16 10:13:53 UTC - Size: 160.71 KB - 140 views
[2022-03-16 16:45:05]
It took less than a minute to download this data for us, at a 1 Second Intraday Data Storage Time Unit . This is what we see:
https://www.sierrachart.com/image.php?Image=1647448992275.png
To re-download the data, you need to go through the procedure here and follow through the instructions step-by-step:
Date Time Of Last Edit: 2022-03-16 16:48:17
