Date/Time: Mon, 10 Mar 2025 02:46:10 +0000
MQOJ contract is frozen
View Count: 490
[2022-03-15 15:05:14] |
User337150 - Posts: 3 |
I have been having constant issues with MQOJ not working. On other platforms the quote is updating as it should.
[2022-03-15 15:59:59] |
We are not observing a problem. This is what we currently see: https://www.sierrachart.com/image.php?Image=1647360016372.png Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-15 16:00:21
