Date/Time: Mon, 10 Mar 2025 03:00:20 +0000
BidVolume and AskVolume - global data feed
View Count: 417
[2022-03-14 22:39:21] |
User411902 - Posts: 4 |
Hello, I am using global data feed to get the Historical BidVolume and AskVolume. I am not able to see . Global data feed says that it is the problem with the sierrachart and they have done all the fixes on their side. Do you have estimated time for the fix? Thanks, Anson |
[2022-03-15 13:16:52] |
We need to check with them on this. This would all be controlled by them but we may need to give them some technical guidance to resolve the issue.
