Date/Time: Mon, 10 Mar 2025 02:53:35 +0000
Trading disabled
View Count: 700
[2022-03-14 17:50:02] |
User585104 - Posts: 148 |
Hi, I think I have everything set up correctly but I just entered a test trade and I get the following message 3 times with consecutive ID numbers. Teton CME Order Routing (Order reject). Info: Trading is disabled. Internal Order ID: 737. Service Order ID: (none). Symbol: MESM22_FUT_CME. Account: xxxxxxxx| 2022-03-14 17:43:36.013 * I have replaced account with x's Do I need to update symbols? If I try to "find symbol" I noticed Futures CME does not say real time in brackets? Thanks |
[2022-03-14 18:04:24] |
Contact your broker about this. Let them know you are getting this rejection "Trading is disabled".
