Date/Time: Fri, 25 Sep 2026 18:59:49 +0000
Teton Order Routing Service and IB
View Count: 1091
| [2022-03-14 15:27:51] |
| User594974 - Posts: 35 |
Thank you. I have a question regarding multiple Denali connections but different trading services. I use Interactive Brokers trading with Denali as the data on a separate computer. Adding Teton for trading through Ironbeam on a different computer won't affect the IB connection in any way will it? I have two Denali connections enabled. |
| [2022-03-14 16:42:34] |
As long as you have 2 connections enabled for the Denali Exchange Data Feed there will not be a problem. Refer to: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
