Date/Time: Mon, 10 Mar 2025 02:08:20 +0000
gbpusd no receve data
View Count: 493
[2022-03-14 15:16:01] |
Ionut Purice - Posts: 1 |
i have no data for GBPUSD.I TRIED EVRITING FOM ONLINE SUPORT NOTING WORKING
[2022-03-14 15:49:44] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings ---- Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
