Date/Time: Mon, 10 Mar 2025 03:01:44 +0000
Number bar volume text color change from white
View Count: 1047
[2022-03-14 15:14:10] |
User474875 - Posts: 7 |
Dear support, I couldn't figure out how to change Number bar volume text color change from white to other colors. Please help https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62353 |
[2022-03-14 17:24:00] |
John - SC Support - Posts: 38516 |
To change the Text colors, you need to enable an option in the Column # Text Coloring Method. Refer to the information here: Numbers Bars: Column # Text Coloring Method Also be aware of the following Input: Numbers Bars: Use Separate Colors for Text Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-15 08:22:24] |
thank you for your reply, but I just want to change the text color from white to for example blue or orange, just like changing the whole background color. the method you provided are conditional based, I just want to change the text color all in once. please help.
[2022-03-15 14:36:24] |
Sorry, we misunderstood. In order to change the default text color you need to change the Input for Default Text Color. Refer to the information here: Numbers Bars: Default Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
