Date/Time: Mon, 10 Mar 2025 02:01:22 +0000
LOW RESPONSE TO ORDER EXECUTION/STOP LOSS AND STOP LIMIT DISABLE
View Count: 479
[2022-03-14 12:43:09] |
Chartsworth - Posts: 1 |
Hi I've experienced low response to order execution and I also noticed my Stop loss and stop limit was disabled and left my trading position opened without any stop loss and stop limit |
[2022-03-14 12:45:56] |
Set the Attached Orders to have a Time in Force of Good till Canceled: Attached Orders: Time In Force And we also definitely/strongly recommend moving to the Teton order Routing Service instead of CQG. This may resolve order latency issues. There is no reason to be using CQG unless you are trading markets other than the CME Group: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-14 13:18:20
