Date/Time: Mon, 10 Mar 2025 03:14:37 +0000
Using the same Custom Study Button with Multiple Studies
View Count: 585
[2022-03-14 10:37:54] |
PS2004 - Posts: 47 |
Hi! I am trying to use the same Custom Study Button with multiple Studies located on different Charts. The Studies do things based on whether the Button's enable state is On or Off. It seems to me that if a Study from a Chart activates the Button, and I have an other Chart selected, the Button won't change it's enable state. If I click to the Chart which triggered the enable state change, the Button appears to be enabled. If I then switch back to an other Chart the enable state disappears. Is there any method to get around this issue? |
[2022-03-15 21:37:42] |
The behavior you see is correct. These custom study button states are specific to individual charts. It is not changeable.
