Date/Time: Sun, 27 Sep 2026 23:12:21 +0000
Determine the origin chart of a drawing that is automatically copied to another chart
View Count: 877
| [2022-03-12 20:57:38] |
| dbtrade - Posts: 24 |
Is it possible to determine which chart a drawing came from? If chart drawings are copied to other charts, can the original chart on which the drawing was created be determined? Perhaps by using the drawing id and referencing some master list or?? I have tried deleting the drawing and I notice that depending on which chart I delete it from, the undo chart drawing option may or may not appear, but I am not clear what that tells me about where the drawing came from. |
| [2022-03-14 12:07:40] |
In this case just copy drawings from one chart only and then you can tell what chart they came from through this setting: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
