Date/Time: Mon, 10 Mar 2025 02:25:13 +0000
Chart Replay date and time not working correctly with TPO charts.
View Count: 663
[2022-03-12 19:57:46] |
ScottK - Posts: 43 |
Hi. I have a chartbook open with three TPO charts. I am trying to replay them all at once, but they won't start on the proper date and time. I selected yesterday's date of 2022-03-11 and the time of 9:30, yet they won't start replaying on that date. They seem to want to start replaying on 2022-03-10 at the "f" evening session! I've also tried it with other dates and it does the same to them. Help. |
[2022-03-13 17:24:27] |
We would have to look into this but this could be. It could be that they will start at the beginning of the TPO Profile when the Date-Time is contained within. Are you specifying the start date and time directly on the Replay Control Panel?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-13 17:24:36
[2022-03-15 19:05:27] |
Yes, I am specifying the start date and time directly on the Replay Control Panel. I tried starting it again from yesterdays open, but once again it didn't work properly. |
[2022-03-17 13:25:29] |
The behavior you see, is how the functionality works and it is not something we can research right now.
[2022-03-17 17:27:00] |
I got it to work, by opening the three TPO's in a new instance of Sierra Chart, so it is do-able. I have no idea why it won't work in the other instance. The time zones, and session times are all set properly. Strange. |
