Date/Time: Wed, 16 Sep 2026 19:17:41 +0000
Flash chart when any alert originally created on that chart is triggered?
View Count: 1410
| [2022-03-12 15:55:25] |
| User656492 - Posts: 160 |
Hello, Good People! Here's a wishlist item: Some of us have many charts constantly displayed, with various alerts set up to fire under various conditions. (Volume, price levels, trend lines, home-grown indicators, etc.). Sometimes it's difficult to know on which chart the alert just triggered. I would like a check box and time option added to the chart settings menu that allows me to cause the chart to change background color when ANY alert on the chart triggers until I click that chart. Example: 20 charts displayed. Price crosses trend line. Trend line alert plays sound and blinks. Which chart? I don't know yet. But if the chart changes background color to yellow I can easily see which one it was, and then click that chart to return its background color back to its "unalerted" color. Note, if the alert is caused by a drawing that is referenced by other charts, the color change would occur only on the chart that is referenced, not the others. I would like to see the source of the alert light up. |
| [2022-03-12 18:29:28] |
| mlt124000 - Posts: 63 |
+1 Interested in this as well. Plus, is it possible.. to have a chart be 'brought forward' on alert... Example Im watching ES fullscreen, while i have NQ/CL/GC/RTY/BTC/etc in the background... an alert triggers on CL which brings that chart 'forwards' for review |
| [2022-03-20 00:32:37] |
There is the Alert Manager, and the functionality to go to a chart that generated the alert: Alerts Manager: Goto Chart If you want to do anything more, use ACSIL. ACSIL can change the chart background color: ACSIL Interface Members - Variables and Arrays: sc.ChartBackgroundColor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-20 02:00:02
| [2022-03-20 03:47:08] |
Thanks, I'm aware of this function but it doesn't do what I need. Perhaps you can put this on a the "maybe in the future" features list. |
