Date/Time: Fri, 02 Oct 2026 17:16:01 +0000
do not copy ACSIL user drawings to other charts
View Count: 1123
[2022-03-12 03:20:55]
onnb - Posts: 666
When "Copy Chart Drawings From Chart #" is set, SC copies all user drawings to the remove chart.
For studies that have "Tool.AddAsUserDrawnDrawing = 1" these are also copied.
Is there a way to suppress copying of ACSIL drawings but still allow the users manual drawings to be copied? Is there a setting somewhere that does this?
[2022-03-12 09:15:32]
User431178 - Posts: 908
You can use the structure member linked below to control that behavior.
Using Drawing Tools From an Advanced Custom Study: s_UseTool::AllowCopyToOtherCharts
[2022-03-12 12:02:23]
Yes post #2 is correct.
