Date/Time: Mon, 10 Mar 2025 02:09:01 +0000
Performing Symbol Rollover changes Tick Size on charts!
View Count: 902
[2022-03-11 23:01:57] |
User719512 - Posts: 299 |
Rolled over charts from H to M, and the tick size/tick compression set on all the charts was reset. This is a huge issue, a major inconvenience, and not helpful in any way. I know Sierra resets tick size on certain conditions, but Performing a Rollover should not be one of them. Please address and fix this issue. |
[2022-03-12 09:20:44] |
User431178 - Posts: 612 |
You can set the option linked below to prevent the settings be altered when changing symbol. Chart Settings: Do Not Change Symbol Settings for Chart on Symbol Change (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) |
[2022-03-12 18:03:02] |
Thanks for the tip. That setting might be good to set to prevent this issue, but breaks setting up a good chartbook for NQ then duplicating it for CL for example. Changing from F.US.ENQH22 to F.US.ENQM22 should not be a "symbol change" and cause all these settings to reset. I still believe Sierra should address this issue.
Date Time Of Last Edit: 2022-03-12 18:05:14
[2022-03-12 18:07:48] |
Also, please see this post for other conditions where tick compression settings break, such a duplicating a chartbook (no symbol change there), or if you give a chartbook to another user and they open it (no symbol change) Duplicate Chart resets Tick Size and it should not |
[2022-03-12 18:22:47] |
As you mentioned footprint charts in the other post, I would ask is there a particular reason why you would change the tick size on a footprint chart instead of using the volume at price multiplier? VAP multiplier is not reset when changing chart symbol and the visual result is the same. |
[2022-03-13 00:00:47] |
Thanks for the suggestion. I may have overlooked that and prob just out of old habits always used tick size. Will give this a go.
[2022-03-13 00:24:01] |
Well, that does not yield the same data in all cases. Tick Size vs Volume at Price Multiplier aggregation method is different And yes, this does have a material impact on how my custom studies work. |
[2022-03-13 11:06:11] |
Did you actually confirm that for yourself? Or is that solely based on a near 3 year old post that, at least from my observations, is no longer accurate? Date Time Of Last Edit: 2022-03-13 11:06:31
[2022-03-14 03:53:52] |
You are correct. It does appear that issue has been resolved from that old case.
