Date/Time: Tue, 26 Nov 2024 06:30:24 +0000
[User Discussion] - Text in Fill Space
View Count: 1315
[2014-04-18 18:07:02] |
User83762 - Posts: 61 |
I want to draw text over my right-margined volume profile in the fill space, so that it is always visible; the text tool does not work because it requires a date/time anchor. Lines with text have similar problems. Stationery text will remain glued to the right side of the chart with an X-axis setting of 150, but does not move with the price scale when scrolling. Can the text tool be changed so that the date/time anchor is optional, perhaps with a checkbox so that the text remains 'locked' at the price and is visible even with a backwards scroll, or is there a better way to accomplish this? Thanks.
Date Time Of Last Edit: 2014-04-18 18:12:17
