Date/Time: Sun, 09 Mar 2025 21:08:32 +0000
Rollover and Volume
View Count: 772
[2022-03-11 18:08:34]
Mauro - Posts: 45
We are rolling over in the ES and I have a question.
When using the continuous contract it seems to me the Volume of the back contract and the Volume of the front contract should be added together, at least for the few days when the rollover happens.
Is there an option in Sierrachart to do that without having to use 2 charts for the 2 contracts and add manually ?
Today, for example, in the ES, half of the volume is in the back contract and half in the front contract but with the continues contract the volume indicator shows only the volume of front contract.
Thank you
M
[2022-03-11 19:41:43]
John - SC Support - Posts: 38516
There is not an option to "add" the volumes together. The volumes you get are based on the volumes for the particular contract from which a particular bar comes from. You can always view which contract is in use for a particular bar by enabling the option for Chart >> Show Rollover Dates. Refer to the information here:
Chart Menu: Show Rollover Dates (Chart menu)
