Date/Time: Sun, 09 Mar 2025 20:31:01 +0000
Pittet Gérald Messages d'erreur lorsque je veux prendre un trad
View Count: 498
[2022-03-11 17:36:14]
Gérald PITTET - Posts: 1
Bonjour,
Voici maintenant à 2 reprises simultanées que la plate forme me refuse 2 trades.
Mon broker me dit de voir avec vous se serait un problème de plate forme.
Voici le message d'erreur
Restant à votre disposition recvez mes cordiales salutations
Bien cordialement
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62304
[2022-03-11 17:50:32]
John - SC Support - Posts: 38516
From Google Translate:
Here now on 2 simultaneous occasions that the platform refuses me 2 trades.
My broker tells me to see with you there would be a platform problem.
Here is the error message
Remaining at your disposal receive my cordial greetings
Best regards
The message in your log gives you the information - "STOP PRICE MUST BE HIGHER THAN BEST BID PRICE". There are a number of possible situations where you could get this, but as an example, if you put in a Sell order with a Stop, that Stop order would have to be above the current Bid Price, or else the Stop would immediately fill (anything below the best bid would be a better price and would fill immediately). Refer to the information here:
Order Types: Stop
