Date/Time: Mon, 10 Mar 2025 03:18:29 +0000
package for constant tick range or volume bars charts on futures
View Count: 584
[2022-03-11 15:15:50]
UserBilly - Posts: 4
hi
what package is required to view historic intraday futures charts that have constant volume bars or constant tick range bars ? I'm interested in CME futures or Eurex futures.
How far will the data go back in time ? Also, is it possible to download the historical data offline ?
regards,
[2022-03-11 16:42:41]
John - SC Support - Posts: 38516
All packages support the use of Volume, Tick, and/or Range bars. Therefore, if you do not need the advanced features (such as TPO or Numbers Bars) then you can just use the Standard Package. Refer to the differences in the packages here:
Description of Service Packages and Pricing: Packages
Assuming you are using our data (Denali Exchange Data Feed), the CME Group tick data goes back to 2011 with 1 minute data before that going back to 2008. The EUREX has tick data back to 2013 with 1 minute data before that going back to 2010. Refer to the information here:
Sierra Chart Historical Data Service: What is Included
Once you acquire the data, it is stored on your system and available offline. This is true for all our data.
[2022-03-15 16:42:55]
hi,
how do I view a historical intraday chart of the continuous futures contract for a symbol e.g. ES. by this I mean at each period of time it will show the chart data for the front month most heavily traded futures contract at that time.
[2022-03-15 16:48:31]
Refer to the following:
Continuous Futures Contract Charts
