Date/Time: Sun, 09 Mar 2025 20:29:54 +0000
Not sure which of these is pulling and which is stacking
View Count: 1128
[2022-03-11 15:00:26] |
CJBuckets - Posts: 20 |
Am I correct in thinking the numbers/percentage within the green/red bar are stacking while the numbers on the outermost left/right side are the pulled orders? Edit: there should be an attached file showing my DOM chart and settings Date Time Of Last Edit: 2022-03-11 15:01:30
[2022-03-11 16:34:51] |
John - SC Support - Posts: 38516 |
The "Bid Pulling/Stacking Column" is the one that has the "680" shown at the bottom. The "Ask Pulling/Stacking Column" is the one that has the "1375" shown at the top. There are not separate columns for Pulling and for Stacking. It is one column showing the ins and outs. Refer to the information here: Global Trade Settings Windows: Bid Market Depth Pulling/Stacking - Left/Center/Right Aligned For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-11 16:52:46] |
Alright appreciate it. If I may ask another question, what do the percentages and numbers indicate in each buy/sell column?
[2022-03-11 17:16:43] |
The whole number is the sum of the Bid and Ask Market Depth respectively. The percentage is the percentage of the total of the Bid and Ask depths for each side. So for the Bid it is 2975/(2975+5028). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
