Date/Time: Sun, 09 Mar 2025 20:30:04 +0000
Question on Trade Copying
View Count: 702
[2022-03-11 14:08:01] |
User274939 - Posts: 13 |
One more question - is there any way to connect other external accounts to my account so they can copy my trades. I have found only the "allocation" option but as far as I understood there is no option to make the other accounts copy my trades with different volume. Only 1:1 as the master account Regards P |
[2022-03-11 14:27:31] |
There is support for a quantity multiplier for the orders allocated to other accounts in the latest prerelease: I understood there is no option to make the other accounts copy my trades with different volume. Only 1:1 as the master account
Only if they are on the same logged in username for the service you are connecting to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-11 14:28:06
[2022-03-11 15:39:18] |
1+1=10 - Posts: 270 |
Hi User274939, If you're referring to external accounts that other people control you can do this with Interactive Brokers, Rithmic, or CQG using Collective2: https://trade.collective2.com/supported-brokers/ If you're referring to external accounts that you control see this thread where as "bradh" has a custom study which does this: Copy trading |
[2022-03-11 15:46:49] |
My idea is to trade with my account and the other accounts to be connected and copy my trades but since they are going to be with different balances I would like to have the option to allocate the volume accordingly. What could be the best option. Regards Petko |
[2022-03-11 15:54:40] |
Assuming these accounts have different usernames, then see the 2nd link above. Reply on that thread that you’d like bradH to message you to get access to his study which copies trades from the main SC instance signed into one username to other SC instances signed into different usernames. Date Time Of Last Edit: 2022-03-11 16:04:48
[2022-03-11 16:00:38] |
Thank you very much! Will get in touch with him soon. Regard Petko |
