Date/Time: Mon, 10 Mar 2025 03:00:20 +0000
How to switch off TABS for Alert Manager
View Count: 540
[2022-03-11 13:16:40]
User361939 - Posts: 167
I would like to switch off e.g TAB "ALERT TEXT", so it wont be visable in alert manager, how can i do that?
Best Regards
imagesierra_tabs.png / V - Attached On 2022-03-11 13:15:12 UTC - Size: 7.77 KB - 132 views
[2022-03-11 13:24:10]
You cannot remove this, but you can change the width to be smaller. And drag it to the right side. All of this is controlled through the header line of that list.
Date Time Of Last Edit: 2022-03-11 13:24:33
[2022-03-11 13:34:09]
OK thank you.
Is this settings available in file so i can transfer into other PCs?
Best Regards
[2022-03-11 13:59:32]
Yes. All of the width and positioning Alert Manager tab columns, are all contained in Sierra4.config
Date Time Of Last Edit: 2022-03-11 13:59:40
[2022-03-14 18:35:32]
I tested it, unfortunatelly, after copied Sierra4.config file ALERT MANAGER, doesn't look like on orginal chart it looks like default.
What could i possible did wrong?
[2022-03-15 02:03:17]
We do not understand the question.
[2022-03-15 13:32:16]
ON Computer A i set alert manager to look certain way.
I copied sierra4.config file(after closing sierra) to have the same look on computer B.
When i pasted filed into Computer B and start SierraChart, ALERT MANGERT doesn't look like Alert manager from computer A, it has tabs fix by default.
