Date/Time: Mon, 10 Mar 2025 02:58:48 +0000
Patch Intraday Data
View Count: 651
[2022-03-11 09:59:17]
User365411 - Posts: 192
I need to fill data holes in a .scid file.
I can't find this command, has it been removed?
Edit >> Patch Intraday Data
Intraday Data Editor: Advanced Editing
If the command is no longer available, is there a way to fill the data holes in a .scid file using a .txt / .csv file?
TY
Date Time Of Last Edit: 2022-03-11 09:59:56
[2022-03-11 11:20:08]
No that does not exist. You just need to follow the information here if there is missing data for a symbol:
Date Time Of Last Edit: 2022-03-11 11:20:23
[2022-03-11 12:07:16]
The problem here is that the fxcm feed for EUSTX50 cfd start at 8:00 AM +1CET, but futures open at 1:15 AM +1CET so there are overnight data that are not collected.
They have GER30 cfd too ( DAX and EURSTOXX50 had same trading hours) but in this case the feed correctly start at 1:15 AM.
So the problem is only for EUSTX50 cfd.
Please can you verify if data from fxcm feed that came to you for this symbol start at 8:00 AM or maybe there is something on your server that cut the overnight hours?
And, again, if data are incomplete from the origin (fxcm feed), there is a way to patch missing holes in .scid files using a .txt file or similar using ACSIL or some kind of tool?
TY
Date Time Of Last Edit: 2022-03-11 12:30:10
[2022-03-14 21:09:59]
All the data that is received for the FXCM CFD symbols is recorded and available. We are not going to do any further examination.
If you need more complete data use the EUREX futures data instead.:
Delayed Exchange Data Feed
