Date/Time: Tue, 11 Mar 2025 17:36:27 +0000
SC OpenGL AMD implementation BUG - Crosshair
View Count: 827
[2022-03-11 04:35:06] |
retox - Posts: 3 |
Hello, regarding to the thread OpenGL update for AMD cards? i'll ask you about a new version with better OpenGL / AMD implementation. It's not working now. The problem is, that if you have enabled opengl with AMD graphics card (i.e. Radeon PRO W5500) and you're using crosshair - all prices and colors are inverted. so you can't see anything. Please work on this bug! i'm running the newest AMD driver (Radeon Pro software version 21.Q4) and SC 2364 64bit. You can try with an AMD card as following: select crosshair, hover over (or actually click somewhere in this chart book for some reason is slightly different) and the text goes inverted. Thanks |
[2022-04-30 15:59:46] |
ScalpRule - Posts: 4 |
I also have this issue. I haven’t found a resolution yet. Getting ready to switch to a NVIDIA card to resolve it.
