Date/Time: Mon, 10 Mar 2025 03:14:17 +0000
Number Bars
View Count: 1028
[2022-03-11 02:31:08]
User447431 - Posts: 29
Hi
How can I place volume by price (total or delta) on the right side of the candle? like the picture attached
About the number bars calculated value, is there a way to move up and down the lines? would like to display total volume in the last line for example, its the second line atm on my charts
imagenb.JPG / V - Attached On 2022-03-11 02:21:16 UTC - Size: 33.75 KB - 273 views
[2022-03-11 15:26:48]
John - SC Support - Posts: 38516
To get the setup for the Numbers Bars, you need to use 2 columns. The second column has the Background Type set to Volume Profile. Refer to the following:
Numbers Bars: Numbers Bars Background Types
For the order of the Numbers Bars Calculated Values, refer to the following:
Numbers Bars: Customizing the Calculated Values Rows Display Order
[2022-03-15 01:55:45]
Im building a imbalance footprint, but the text color seems not to be displaying the correct colors
Set the text color Based on Diagonal Dominant Side AskVol BidVol Percentage and the Column 1 Percent Compare Thresholds to 2.0,3.0,4.0, but the footprint seems to coloring imbalances below 2.0 (200%)
anything i have to change? picture and chartbook attached
image1.png / V - Attached On 2022-03-15 01:52:34 UTC - Size: 146.82 KB - 218 views
image2.JPG / V - Attached On 2022-03-15 01:52:38 UTC - Size: 112.04 KB - 184 views
attachmentFootprintExample.Cht - Attached On 2022-03-15 01:52:45 UTC - Size: 7.66 KB - 163 views
[2022-03-15 14:31:25]
The values between 0 and the first entry in the Compare Thresholds is going to map to the Column x Range 0 Up/Down Color. Therefore, if you do not want the text colored anything between 0 and 2.0, then you need to set the Range 0 colors to white.
