Date/Time: Tue, 15 Sep 2026 06:00:47 +0000
Prices are delayed or not matching
View Count: 1046
| [2022-03-10 15:15:31] |
| User795631 - Posts: 17 |
Prices are not matching my other broker on ES
| [2022-03-10 16:33:32] |
| John - SC Support - Posts: 47889 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 16:37:03] |
ESM22-CME No message box shows up seems like it is moving correctly on time but the prices are off 10 points |
| [2022-03-10 16:58:42] |
If you are not able to see the Message Log window, then select Window >> Reset Windows. The Message Log should show up after that, but if not, then select Window >> Message Log. Then go through the instructions we have given above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 17:31:48] |
Created the DTC Protocol server. | 2022-03-10 17:01:31.916 DTC Protocol Server listening on port 11099. | 2022-03-10 17:01:31.917 Reading Internal Order ID file. | 2022-03-10 17:01:31.917 Reading Trade Orders file. | 2022-03-10 17:01:31.947 Reading Trade Positions file. | 2022-03-10 17:01:31.947 Reading Trade Account Data files. | 2022-03-10 17:01:31.947 Software version: 2362 64-bit | 2022-03-10 17:01:31.954 Primary Thread ID: 2584 | 2022-03-10 17:01:31.954 Usage end date: 2022-04-14 | 2022-03-10 17:01:31.954 Enabled for: Advanced Features 2. | 2022-03-10 17:01:31.954 Enabled for: Sierra Chart Historical Data Service. | 2022-03-10 17:01:31.954 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-03-10 17:01:31.954 Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-10 17:01:31.954 Enabled for exchange2: CME (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: CBOT (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: COMEX (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: fairx_exchange.data | 2022-03-10 17:01:31.954 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-10 17:01:31.954 Current selected Data/Trading service: SC Data - All Services | 2022-03-10 17:01:31.954 Custom symbol settings values: enabled | 2022-03-10 17:01:31.954 Chart Update Interval: 500 | 2022-03-10 17:01:31.954 Intraday Data Storage Time Unit: 0 | 2022-03-10 17:01:31.954 Time Zone: +00:00:00 (UTC+00) | 2022-03-10 17:01:31.954 2022-03-10 17:01:31 Local computer time in UTC | 2022-03-10 17:01:31.954 2022-03-10 17:01:31 Local computer time in SC Time Zone | 2022-03-10 17:01:31.954 2022-03-10 17:01:29 Server time in UTC | 2022-03-10 17:01:31.954 Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-03-10 17:01:31.954 Program path: C:\SierraChart\ | 2022-03-10 17:01:31.954 Data Files path: C:\SierraChart\Data\ | 2022-03-10 17:01:31.954 OS Version Number: 10.0 | 2022-03-10 17:01:31.954 Locale Setting: C | 2022-03-10 17:01:31.954 DLLs: auto_vbp_fixes_64.dll, BetterVap_64.dll, NotTimeBased_64.dll, tnp640304.dll, UserContributedStudies_64.dll, volume_at_price_64.dll | 2022-03-10 17:01:31.954 Allowed protected custom studies: DRAW TNP DLL | 2022-03-10 17:01:31.954 Created the DTC Protocol historical data server. | 2022-03-10 17:01:31.954 HD Server Manager | Listening on port 11098. | 2022-03-10 17:01:31.954 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-03-10 17:01:31.955 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:01:31.999 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-10 17:01:32.174 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-10 17:01:32.174 Received 5 login tokens. | 2022-03-10 17:01:32.505 Symbol settings MD5 received. Request ID: 1. | 2022-03-10 17:01:34.211 Symbol settings are up-to-date for scdataallservices. | 2022-03-10 17:01:34.211 Error loading: C:\SierraChart\Data\TNP_64 (1).dll. File not found or may be missing SCDLLName line. | 2022-03-10 17:01:35.722 Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffa0e6d0000 | 2022-03-10 17:01:35.735 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:35.749 ESM22-CME [CV] 240 Min #8 | Performing continuous chart historical Daily data download for symbol ESH22-CME starting at last date in file. | 2022-03-10 17:01:35.750 Starting DelayedDownloadMonitoringTimer | 2022-03-10 17:01:35.750 Starting HDTimeoutTimer | 2022-03-10 17:01:35.750 Added historical Daily data request for ESH22-CME to the queue. | 2022-03-10 17:01:35.750 Triggering next historical data download in queue. | 2022-03-10 17:01:35.750 ESM22-CME [CV] 240 Min #8 | Performing continuous chart historical Daily data download for symbol ESM22-CME starting at last date in file. | 2022-03-10 17:01:35.750 Added historical Daily data request for ESM22-CME to the queue. | 2022-03-10 17:01:35.750 ESM22-CME [CV] 240 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.762 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:35.787 ESM22-CME [CV] 15 Min #9 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.800 Loading DLL: C:\SierraChart\Data\tnp640304.dll (tnp640304.dll). Handle: 66000000 | 2022-03-10 17:01:35.815 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:35.826 ESM22-CME [CV] Renko 8t #6 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.833 Mapping ESH22-CME to ESH22. Service code: cme | 2022-03-10 17:01:35.842 Using symbol data fast lookup vector | 2022-03-10 17:01:35.842 HD Request # 1 | Downloading Historical Daily chart data for ESH22-CME. Starting date: 2022-03-07. Service: scdataallservices | 2022-03-10 17:01:35.842 HD Request # 1 | Requesting historical Daily data for ESH22 starting at 2022-03-06. SC External HD service. | 2022-03-10 17:01:36.626 HD Request # 1 | Receiving historical Daily data for ESH22-CME starting at 2022-03-07 | 2022-03-10 17:01:36.996 HD Request # 1 | Writing historical Daily data to the file ESH22-CME.dly | 2022-03-10 17:01:36.996 HD Request # 1 | Bytes received: 184 | 2022-03-10 17:01:36.997 HD Request # 1 | Received 3 Daily data records from 2022-03-07 00:00:00 to 2022-03-09 00:00:00 (3.0 days) and wrote 3 records for ESH22-CME | 2022-03-10 17:01:36.997 HD Request # 1 | Completion time: 1s | 2022-03-10 17:01:36.997 HD Request # 1 | Daily data download complete for ESH22-CME. Unique request ID: 1 | 2022-03-10 17:01:36.997 Removing historical data download ID 1. | 2022-03-10 17:01:36.997 Triggering next historical data download in queue. | 2022-03-10 17:01:36.997 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:01:36.997 HD Request # 2 | Downloading Historical Daily chart data for ESM22-CME. Starting date: 2022-03-07. Service: scdataallservices | 2022-03-10 17:01:36.998 HD Request # 2 | Requesting historical Daily data for ESM22 starting at 2022-03-06. SC External HD service. | 2022-03-10 17:01:37.779 HD Request # 2 | Receiving historical Daily data for ESM22-CME starting at 2022-03-07 | 2022-03-10 17:01:37.992 HD Request # 2 | Writing historical Daily data to the file ESM22-CME.dly | 2022-03-10 17:01:37.993 HD Request # 2 | Bytes received: 173 | 2022-03-10 17:01:37.994 HD Request # 2 | Received 3 Daily data records from 2022-03-07 00:00:00 to 2022-03-09 00:00:00 (3.0 days) and wrote 3 records for ESM22-CME | 2022-03-10 17:01:37.994 HD Request # 2 | Completion time: 1s | 2022-03-10 17:01:37.994 HD Request # 2 | Daily data download complete for ESM22-CME. Unique request ID: 2 | 2022-03-10 17:01:37.994 Removing historical data download ID 2. | 2022-03-10 17:01:37.994 Triggering next historical data download in queue. | 2022-03-10 17:01:37.994 No download requests in the queue to start downloads for. | 2022-03-10 17:01:37.994 ESM22-CME [CV] 240 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.248 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:38.249 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.252 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.252 ESM22-CME [CV] 15 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.277 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:38.278 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.281 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.281 ESM22-CME [CV] Renko 8t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.324 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:38.325 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.327 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.327 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:38.748 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.770 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.770 SC Data - All Services | Connected to server complete. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:38.780 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.796 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.796 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:38.825 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.834 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.834 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:01:39.246 Using symbol data fast lookup vector | 2022-03-10 17:01:39.246 | Starting real-time market data updates for: ESM22-CME (ESM22). ID: 1 Service code: cme | 2022-03-10 17:01:39.246 | Connecting to the server ds13.sierracharts.com. Port 10048 | 2022-03-10 17:01:39.246 | Requesting security definition data for: ESM22-CME (ESM22). ID: 1 | 2022-03-10 17:01:39.246 Starting DelayedDownloadMonitoringTimer | 2022-03-10 17:01:39.246 Starting HDTimeoutTimer | 2022-03-10 17:01:39.246 Added historical Intraday data request for ESM22-CME to the queue. | 2022-03-10 17:01:39.246 Intraday data recording state for symbol ESM22-CME is set to download 'Pending'. | 2022-03-10 17:01:39.246 Triggering next historical data download in queue. | 2022-03-10 17:01:39.246 DTC Client socket (1) | Creating socket. | 2022-03-10 17:01:39.246 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-10 17:01:39.246 DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2022-03-10 17:01:39.246 Delaying start of download for ESM22-CME | 2022-03-10 17:01:39.247 | Network connection to server complete. | 2022-03-10 17:01:39.294 | Starting socket receive thread. | 2022-03-10 17:01:39.294 | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-10 17:01:39.294 | Setting DTC encoding to Binary VLS | 2022-03-10 17:01:39.360 | Sending logon request message. | 2022-03-10 17:01:39.360 | Received logon response. | 2022-03-10 17:01:40.500 | Server Name: SC Realtime Server. | 2022-03-10 17:01:40.500 | Server protocol version: 8. Client protocol version: 8 | 2022-03-10 17:01:40.500 | Successfully connected. | 2022-03-10 17:01:40.500 | Trading is not supported. | 2022-03-10 17:01:40.500 | Restarting real-time data updates for symbol: ESM22-CME -> ESM22 | 2022-03-10 17:01:40.500 | Received security definition for symbol ESM22-CME | 2022-03-10 17:01:40.648 HD Request # 3 | Downloading Intraday chart data for ESM22-CME to the file ESM22-CME.scid. Service: cme | 2022-03-10 17:01:45.247 HD Request # 3 | Download start date-time: 2022-03-10 16:50:14.000000. File last date-time: 2022-03-10 16:50:14.551000 | 2022-03-10 17:01:45.248 HD Request # 3 | Using server: ds23.sierracharts.com port 10149 | 2022-03-10 17:01:45.248 Socket (2) | Creating socket. | 2022-03-10 17:01:45.251 Socket (2) | New receive buffer size: 5242880 | 2022-03-10 17:01:45.251 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-10 17:01:45.251 HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-03-10 17:01:45.396 HD Request # 3 | Sending historical data logon request message. | 2022-03-10 17:01:45.396 HD Request # 3 | Requesting Intraday data. Start date-time: 2022-03-10 16:50:14. Record interval: 0. Symbol: ESM22 | 2022-03-10 17:01:45.925 HD Request # 3 | Decompressing data. | 2022-03-10 17:01:45.988 HD Request # 3 | Receiving Intraday data for ESM22-CME starting at 2022-03-10 16:50:14.517000 | 2022-03-10 17:01:46.114 Socket (2) | CloseSocket call. | 2022-03-10 17:01:46.115 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:01:46.115 Historical data download thread signaled to stop. | 2022-03-10 17:01:46.115 HD Request # 3 | Timestamp of first Intraday data file record written: 2022-03-10 16:50:14.702000 | 2022-03-10 17:01:46.115 HD Request # 3 | Received 2660 Intraday data records from 2022-03-10 16:50:14.517000 to 2022-03-10 17:01:42.120003 (11.5 minutes) and wrote 2656 records for ESM22-CME | 2022-03-10 17:01:46.115 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-03-10 17:01:42.120003 | 2022-03-10 17:01:46.120 Added 8 Time and Sales records to Intraday data file for ESM22-CME after download. | 2022-03-10 17:01:46.120 HD Request # 3 | Completion time: 1s | 2022-03-10 17:01:46.120 HD Request # 3 | Intraday data download complete for ESM22-CME. Unique request ID: 3 | 2022-03-10 17:01:46.120 Removing historical data download ID 3. | 2022-03-10 17:01:46.120 Real-time Intraday chart data file updates started for ESM22-CME | 2022-03-10 17:01:46.120 Intraday chart data file opened for ESM22-CME | 2022-03-10 17:01:46.120 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-03-10 17:01:46.120 Triggering next historical data download in queue. | 2022-03-10 17:01:46.120 No download requests in the queue to start downloads for. | 2022-03-10 17:01:46.120 Socket (2) | Socket gracefully closed by remote side. | 2022-03-10 17:01:46.178 Socket (2) | Closed. | 2022-03-10 17:01:46.178 Opened cached Intraday file: C:\SierraChart\Data\ESM22-CME.scid. Thread ID: 10596 | 2022-03-10 17:01:47.041 File >> Disconnect selected. | 2022-03-10 17:14:00.840 | Waiting for socket receive thread to end | 2022-03-10 17:14:00.841 DTC Client socket (1) | CloseSocket call. | 2022-03-10 17:14:00.841 | Disconnected from the server. | 2022-03-10 17:14:00.841 SC Data - All Services | Disconnected. | 2022-03-10 17:14:00.841 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:14:00.841 SC Data - All Services | Connected to server complete. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:14:03.824 Using symbol data fast lookup vector | 2022-03-10 17:14:03.824 | Starting real-time market data updates for: ESM22-CME (ESM22). ID: 1 Service code: cme | 2022-03-10 17:14:03.824 | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-03-10 17:14:03.824 | Requesting security definition data for: ESM22-CME (ESM22). ID: 1 | 2022-03-10 17:14:03.824 Added historical Intraday data request for ESM22-CME to the queue. | 2022-03-10 17:14:03.824 Intraday data recording state for symbol ESM22-CME is set to download 'Pending'. | 2022-03-10 17:14:03.824 Triggering next historical data download in queue. | 2022-03-10 17:14:03.824 DTC Client socket (2) | Creating socket. | 2022-03-10 17:14:03.825 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-10 17:14:03.825 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-10 17:14:03.825 Delaying start of download for ESM22-CME | 2022-03-10 17:14:03.832 | Network connection to server complete. | 2022-03-10 17:14:03.894 | Starting socket receive thread. | 2022-03-10 17:14:03.894 | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-10 17:14:03.894 | Setting DTC encoding to Binary VLS | 2022-03-10 17:14:03.988 | Sending logon request message. | 2022-03-10 17:14:03.988 | Received logon response. | 2022-03-10 17:14:04.803 | Server Name: SC Realtime Server. | 2022-03-10 17:14:04.803 | Server protocol version: 8. Client protocol version: 8 | 2022-03-10 17:14:04.803 | Successfully connected. | 2022-03-10 17:14:04.803 | Trading is not supported. | 2022-03-10 17:14:04.803 | Restarting real-time data updates for symbol: ESM22-CME -> ESM22 | 2022-03-10 17:14:04.803 | Received security definition for symbol ESM22-CME | 2022-03-10 17:14:04.957 HD Request # 4 | Downloading Intraday chart data for ESM22-CME to the file ESM22-CME.scid. Service: cme | 2022-03-10 17:14:09.247 HD Request # 4 | Download start date-time: 2022-03-10 17:13:58.000000. File last date-time: 2022-03-10 17:13:58.855000 | 2022-03-10 17:14:09.247 HD Request # 4 | Using server: ds21.sierracharts.com port 10150 | 2022-03-10 17:14:09.247 Socket (3) | Creating socket. | 2022-03-10 17:14:09.247 Socket (3) | New receive buffer size: 5242880 | 2022-03-10 17:14:09.247 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-10 17:14:09.247 HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-03-10 17:14:09.385 HD Request # 4 | Sending historical data logon request message. | 2022-03-10 17:14:09.385 HD Request # 4 | Requesting Intraday data. Start date-time: 2022-03-10 17:13:58. Record interval: 0. Symbol: ESM22 | 2022-03-10 17:14:09.909 HD Request # 4 | Decompressing data. | 2022-03-10 17:14:09.970 HD Request # 4 | Receiving Intraday data for ESM22-CME starting at 2022-03-10 17:13:58.225000 | 2022-03-10 17:14:09.971 Socket (3) | CloseSocket call. | 2022-03-10 17:14:09.971 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:14:09.971 Historical data download thread signaled to stop. | 2022-03-10 17:14:09.971 HD Request # 4 | Timestamp of first Intraday data file record written: 2022-03-10 17:13:59.506000 | 2022-03-10 17:14:09.971 HD Request # 4 | Received 33 Intraday data records from 2022-03-10 17:13:58.225000 to 2022-03-10 17:14:06.288003 (8.1 seconds) and wrote 14 records for ESM22-CME | 2022-03-10 17:14:09.971 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2022-03-10 17:14:06.288003 | 2022-03-10 17:14:09.975 Added 10 Time and Sales records to Intraday data file for ESM22-CME after download. | 2022-03-10 17:14:09.975 HD Request # 4 | Completion time: 0s | 2022-03-10 17:14:09.975 HD Request # 4 | Intraday data download complete for ESM22-CME. Unique request ID: 4 | 2022-03-10 17:14:09.975 Removing historical data download ID 4. | 2022-03-10 17:14:09.975 Real-time Intraday chart data file updates started for ESM22-CME | 2022-03-10 17:14:09.975 Intraday chart data file opened for ESM22-CME | 2022-03-10 17:14:09.975 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-03-10 17:14:09.975 Triggering next historical data download in queue. | 2022-03-10 17:14:09.975 No download requests in the queue to start downloads for. | 2022-03-10 17:14:09.975 Socket (3) | Socket gracefully closed by remote side. | 2022-03-10 17:14:10.035 Socket (3) | Closed. | 2022-03-10 17:14:10.035 Opened cached Intraday file: C:\SierraChart\Data\ESM22-CME.scid. Thread ID: 10596 | 2022-03-10 17:14:13.106 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-03-10 17:16:29.074 DTC Client socket (1) | Closed. | 2022-03-10 17:16:29.074 DTC Client socket (1) | Deleting network socket now after delay. | 2022-03-10 17:16:59.077 |
| [2022-03-10 18:31:41] |
We are not seeing anything in your log that shows that there is any issue. Make sure you are at the end of the chart by selecting the End key on your keyboard. After you select that button, the marker in the bottom right corner of your Sierra Chart window should be green. Refer to the following: Working With Charts: Chart Settings Indicators at Lower Right of Chart If the bars are still not matching the price, then get us a screenshot of what you are seeing. You can post a screenshot by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 20:52:59] |
I am at the end and it is off for 10 to 9 points.
| [2022-03-10 21:07:21] |
Created the DTC Protocol server. | 2022-03-10 17:01:31.916 DTC Protocol Server listening on port 11099. | 2022-03-10 17:01:31.917 Reading Internal Order ID file. | 2022-03-10 17:01:31.917 Reading Trade Orders file. | 2022-03-10 17:01:31.947 Reading Trade Positions file. | 2022-03-10 17:01:31.947 Reading Trade Account Data files. | 2022-03-10 17:01:31.947 Software version: 2362 64-bit | 2022-03-10 17:01:31.954 Primary Thread ID: 2584 | 2022-03-10 17:01:31.954 Usage end date: 2022-04-14 | 2022-03-10 17:01:31.954 Enabled for: Advanced Features 2. | 2022-03-10 17:01:31.954 Enabled for: Sierra Chart Historical Data Service. | 2022-03-10 17:01:31.954 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-03-10 17:01:31.954 Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-10 17:01:31.954 Enabled for exchange2: CME (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: CBOT (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: COMEX (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-03-10 17:01:31.954 Enabled for exchange2: fairx_exchange.data | 2022-03-10 17:01:31.954 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-10 17:01:31.954 Current selected Data/Trading service: SC Data - All Services | 2022-03-10 17:01:31.954 Custom symbol settings values: enabled | 2022-03-10 17:01:31.954 Chart Update Interval: 500 | 2022-03-10 17:01:31.954 Intraday Data Storage Time Unit: 0 | 2022-03-10 17:01:31.954 Time Zone: +00:00:00 (UTC+00) | 2022-03-10 17:01:31.954 2022-03-10 17:01:31 Local computer time in UTC | 2022-03-10 17:01:31.954 2022-03-10 17:01:31 Local computer time in SC Time Zone | 2022-03-10 17:01:31.954 2022-03-10 17:01:29 Server time in UTC | 2022-03-10 17:01:31.954 Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-03-10 17:01:31.954 Program path: C:\SierraChart\ | 2022-03-10 17:01:31.954 Data Files path: C:\SierraChart\Data\ | 2022-03-10 17:01:31.954 OS Version Number: 10.0 | 2022-03-10 17:01:31.954 Locale Setting: C | 2022-03-10 17:01:31.954 DLLs: auto_vbp_fixes_64.dll, BetterVap_64.dll, NotTimeBased_64.dll, tnp640304.dll, UserContributedStudies_64.dll, volume_at_price_64.dll | 2022-03-10 17:01:31.954 Allowed protected custom studies: DRAW TNP DLL | 2022-03-10 17:01:31.954 Created the DTC Protocol historical data server. | 2022-03-10 17:01:31.954 HD Server Manager | Listening on port 11098. | 2022-03-10 17:01:31.954 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-03-10 17:01:31.955 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:01:31.999 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-10 17:01:32.174 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-10 17:01:32.174 Received 5 login tokens. | 2022-03-10 17:01:32.505 Symbol settings MD5 received. Request ID: 1. | 2022-03-10 17:01:34.211 Symbol settings are up-to-date for scdataallservices. | 2022-03-10 17:01:34.211 Error loading: C:\SierraChart\Data\TNP_64 (1).dll. File not found or may be missing SCDLLName line. | 2022-03-10 17:01:35.722 Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffa0e6d0000 | 2022-03-10 17:01:35.735 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:35.749 ESM22-CME [CV] 240 Min #8 | Performing continuous chart historical Daily data download for symbol ESH22-CME starting at last date in file. | 2022-03-10 17:01:35.750 Starting DelayedDownloadMonitoringTimer | 2022-03-10 17:01:35.750 Starting HDTimeoutTimer | 2022-03-10 17:01:35.750 Added historical Daily data request for ESH22-CME to the queue. | 2022-03-10 17:01:35.750 Triggering next historical data download in queue. | 2022-03-10 17:01:35.750 ESM22-CME [CV] 240 Min #8 | Performing continuous chart historical Daily data download for symbol ESM22-CME starting at last date in file. | 2022-03-10 17:01:35.750 Added historical Daily data request for ESM22-CME to the queue. | 2022-03-10 17:01:35.750 ESM22-CME [CV] 240 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.762 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:35.787 ESM22-CME [CV] 15 Min #9 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.800 Loading DLL: C:\SierraChart\Data\tnp640304.dll (tnp640304.dll). Handle: 66000000 | 2022-03-10 17:01:35.815 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:35.826 ESM22-CME [CV] Renko 8t #6 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-03-10 17:01:35.833 Mapping ESH22-CME to ESH22. Service code: cme | 2022-03-10 17:01:35.842 Using symbol data fast lookup vector | 2022-03-10 17:01:35.842 HD Request # 1 | Downloading Historical Daily chart data for ESH22-CME. Starting date: 2022-03-07. Service: scdataallservices | 2022-03-10 17:01:35.842 HD Request # 1 | Requesting historical Daily data for ESH22 starting at 2022-03-06. SC External HD service. | 2022-03-10 17:01:36.626 HD Request # 1 | Receiving historical Daily data for ESH22-CME starting at 2022-03-07 | 2022-03-10 17:01:36.996 HD Request # 1 | Writing historical Daily data to the file ESH22-CME.dly | 2022-03-10 17:01:36.996 HD Request # 1 | Bytes received: 184 | 2022-03-10 17:01:36.997 HD Request # 1 | Received 3 Daily data records from 2022-03-07 00:00:00 to 2022-03-09 00:00:00 (3.0 days) and wrote 3 records for ESH22-CME | 2022-03-10 17:01:36.997 HD Request # 1 | Completion time: 1s | 2022-03-10 17:01:36.997 HD Request # 1 | Daily data download complete for ESH22-CME. Unique request ID: 1 | 2022-03-10 17:01:36.997 Removing historical data download ID 1. | 2022-03-10 17:01:36.997 Triggering next historical data download in queue. | 2022-03-10 17:01:36.997 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:01:36.997 HD Request # 2 | Downloading Historical Daily chart data for ESM22-CME. Starting date: 2022-03-07. Service: scdataallservices | 2022-03-10 17:01:36.998 HD Request # 2 | Requesting historical Daily data for ESM22 starting at 2022-03-06. SC External HD service. | 2022-03-10 17:01:37.779 HD Request # 2 | Receiving historical Daily data for ESM22-CME starting at 2022-03-07 | 2022-03-10 17:01:37.992 HD Request # 2 | Writing historical Daily data to the file ESM22-CME.dly | 2022-03-10 17:01:37.993 HD Request # 2 | Bytes received: 173 | 2022-03-10 17:01:37.994 HD Request # 2 | Received 3 Daily data records from 2022-03-07 00:00:00 to 2022-03-09 00:00:00 (3.0 days) and wrote 3 records for ESM22-CME | 2022-03-10 17:01:37.994 HD Request # 2 | Completion time: 1s | 2022-03-10 17:01:37.994 HD Request # 2 | Daily data download complete for ESM22-CME. Unique request ID: 2 | 2022-03-10 17:01:37.994 Removing historical data download ID 2. | 2022-03-10 17:01:37.994 Triggering next historical data download in queue. | 2022-03-10 17:01:37.994 No download requests in the queue to start downloads for. | 2022-03-10 17:01:37.994 ESM22-CME [CV] 240 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.248 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:38.249 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.252 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.252 ESM22-CME [CV] 15 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.277 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:38.278 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.281 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.281 ESM22-CME [CV] Renko 8t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-03-10 17:01:38.324 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:38.325 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.327 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.327 ESM22-CME [CV] 240 Min #8 | Reloading chart. | 2022-03-10 17:01:38.748 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.770 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.770 SC Data - All Services | Connected to server complete. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 Triggering next historical data download in queue. | 2022-03-10 17:01:38.771 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 No download requests in the queue to start downloads for. | 2022-03-10 17:01:38.772 ESM22-CME [CV] 15 Min #9 | Reloading chart. | 2022-03-10 17:01:38.780 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.796 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.796 ESM22-CME [CV] Renko 8t #6 | Reloading chart. | 2022-03-10 17:01:38.825 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 17:01:38.834 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 17:01:38.834 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:01:39.246 Using symbol data fast lookup vector | 2022-03-10 17:01:39.246 | Starting real-time market data updates for: ESM22-CME (ESM22). ID: 1 Service code: cme | 2022-03-10 17:01:39.246 | Connecting to the server ds13.sierracharts.com. Port 10048 | 2022-03-10 17:01:39.246 | Requesting security definition data for: ESM22-CME (ESM22). ID: 1 | 2022-03-10 17:01:39.246 Starting DelayedDownloadMonitoringTimer | 2022-03-10 17:01:39.246 Starting HDTimeoutTimer | 2022-03-10 17:01:39.246 Added historical Intraday data request for ESM22-CME to the queue. | 2022-03-10 17:01:39.246 Intraday data recording state for symbol ESM22-CME is set to download 'Pending'. | 2022-03-10 17:01:39.246 Triggering next historical data download in queue. | 2022-03-10 17:01:39.246 DTC Client socket (1) | Creating socket. | 2022-03-10 17:01:39.246 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-10 17:01:39.246 DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2022-03-10 17:01:39.246 Delaying start of download for ESM22-CME | 2022-03-10 17:01:39.247 | Network connection to server complete. | 2022-03-10 17:01:39.294 | Starting socket receive thread. | 2022-03-10 17:01:39.294 | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-10 17:01:39.294 | Setting DTC encoding to Binary VLS | 2022-03-10 17:01:39.360 | Sending logon request message. | 2022-03-10 17:01:39.360 | Received logon response. | 2022-03-10 17:01:40.500 | Server Name: SC Realtime Server. | 2022-03-10 17:01:40.500 | Server protocol version: 8. Client protocol version: 8 | 2022-03-10 17:01:40.500 | Successfully connected. | 2022-03-10 17:01:40.500 | Trading is not supported. | 2022-03-10 17:01:40.500 | Restarting real-time data updates for symbol: ESM22-CME -> ESM22 | 2022-03-10 17:01:40.500 | Received security definition for symbol ESM22-CME | 2022-03-10 17:01:40.648 HD Request # 3 | Downloading Intraday chart data for ESM22-CME to the file ESM22-CME.scid. Service: cme | 2022-03-10 17:01:45.247 HD Request # 3 | Download start date-time: 2022-03-10 16:50:14.000000. File last date-time: 2022-03-10 16:50:14.551000 | 2022-03-10 17:01:45.248 HD Request # 3 | Using server: ds23.sierracharts.com port 10149 | 2022-03-10 17:01:45.248 Socket (2) | Creating socket. | 2022-03-10 17:01:45.251 Socket (2) | New receive buffer size: 5242880 | 2022-03-10 17:01:45.251 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-10 17:01:45.251 HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-03-10 17:01:45.396 HD Request # 3 | Sending historical data logon request message. | 2022-03-10 17:01:45.396 HD Request # 3 | Requesting Intraday data. Start date-time: 2022-03-10 16:50:14. Record interval: 0. Symbol: ESM22 | 2022-03-10 17:01:45.925 HD Request # 3 | Decompressing data. | 2022-03-10 17:01:45.988 HD Request # 3 | Receiving Intraday data for ESM22-CME starting at 2022-03-10 16:50:14.517000 | 2022-03-10 17:01:46.114 Socket (2) | CloseSocket call. | 2022-03-10 17:01:46.115 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:01:46.115 Historical data download thread signaled to stop. | 2022-03-10 17:01:46.115 HD Request # 3 | Timestamp of first Intraday data file record written: 2022-03-10 16:50:14.702000 | 2022-03-10 17:01:46.115 HD Request # 3 | Received 2660 Intraday data records from 2022-03-10 16:50:14.517000 to 2022-03-10 17:01:42.120003 (11.5 minutes) and wrote 2656 records for ESM22-CME | 2022-03-10 17:01:46.115 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-03-10 17:01:42.120003 | 2022-03-10 17:01:46.120 Added 8 Time and Sales records to Intraday data file for ESM22-CME after download. | 2022-03-10 17:01:46.120 HD Request # 3 | Completion time: 1s | 2022-03-10 17:01:46.120 HD Request # 3 | Intraday data download complete for ESM22-CME. Unique request ID: 3 | 2022-03-10 17:01:46.120 Removing historical data download ID 3. | 2022-03-10 17:01:46.120 Real-time Intraday chart data file updates started for ESM22-CME | 2022-03-10 17:01:46.120 Intraday chart data file opened for ESM22-CME | 2022-03-10 17:01:46.120 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-03-10 17:01:46.120 Triggering next historical data download in queue. | 2022-03-10 17:01:46.120 No download requests in the queue to start downloads for. | 2022-03-10 17:01:46.120 Socket (2) | Socket gracefully closed by remote side. | 2022-03-10 17:01:46.178 Socket (2) | Closed. | 2022-03-10 17:01:46.178 Opened cached Intraday file: C:\SierraChart\Data\ESM22-CME.scid. Thread ID: 10596 | 2022-03-10 17:01:47.041 File >> Disconnect selected. | 2022-03-10 17:14:00.840 | Waiting for socket receive thread to end | 2022-03-10 17:14:00.841 DTC Client socket (1) | CloseSocket call. | 2022-03-10 17:14:00.841 | Disconnected from the server. | 2022-03-10 17:14:00.841 SC Data - All Services | Disconnected. | 2022-03-10 17:14:00.841 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:14:00.841 SC Data - All Services | Connected to server complete. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 Triggering next historical data download in queue. | 2022-03-10 17:14:03.799 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 No download requests in the queue to start downloads for. | 2022-03-10 17:14:03.801 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 17:14:03.824 Using symbol data fast lookup vector | 2022-03-10 17:14:03.824 | Starting real-time market data updates for: ESM22-CME (ESM22). ID: 1 Service code: cme | 2022-03-10 17:14:03.824 | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-03-10 17:14:03.824 | Requesting security definition data for: ESM22-CME (ESM22). ID: 1 | 2022-03-10 17:14:03.824 Added historical Intraday data request for ESM22-CME to the queue. | 2022-03-10 17:14:03.824 Intraday data recording state for symbol ESM22-CME is set to download 'Pending'. | 2022-03-10 17:14:03.824 Triggering next historical data download in queue. | 2022-03-10 17:14:03.824 DTC Client socket (2) | Creating socket. | 2022-03-10 17:14:03.825 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-10 17:14:03.825 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-10 17:14:03.825 Delaying start of download for ESM22-CME | 2022-03-10 17:14:03.832 | Network connection to server complete. | 2022-03-10 17:14:03.894 | Starting socket receive thread. | 2022-03-10 17:14:03.894 | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-10 17:14:03.894 | Setting DTC encoding to Binary VLS | 2022-03-10 17:14:03.988 | Sending logon request message. | 2022-03-10 17:14:03.988 | Received logon response. | 2022-03-10 17:14:04.803 | Server Name: SC Realtime Server. | 2022-03-10 17:14:04.803 | Server protocol version: 8. Client protocol version: 8 | 2022-03-10 17:14:04.803 | Successfully connected. | 2022-03-10 17:14:04.803 | Trading is not supported. | 2022-03-10 17:14:04.803 | Restarting real-time data updates for symbol: ESM22-CME -> ESM22 | 2022-03-10 17:14:04.803 | Received security definition for symbol ESM22-CME | 2022-03-10 17:14:04.957 HD Request # 4 | Downloading Intraday chart data for ESM22-CME to the file ESM22-CME.scid. Service: cme | 2022-03-10 17:14:09.247 HD Request # 4 | Download start date-time: 2022-03-10 17:13:58.000000. File last date-time: 2022-03-10 17:13:58.855000 | 2022-03-10 17:14:09.247 HD Request # 4 | Using server: ds21.sierracharts.com port 10150 | 2022-03-10 17:14:09.247 Socket (3) | Creating socket. | 2022-03-10 17:14:09.247 Socket (3) | New receive buffer size: 5242880 | 2022-03-10 17:14:09.247 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-10 17:14:09.247 HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-03-10 17:14:09.385 HD Request # 4 | Sending historical data logon request message. | 2022-03-10 17:14:09.385 HD Request # 4 | Requesting Intraday data. Start date-time: 2022-03-10 17:13:58. Record interval: 0. Symbol: ESM22 | 2022-03-10 17:14:09.909 HD Request # 4 | Decompressing data. | 2022-03-10 17:14:09.970 HD Request # 4 | Receiving Intraday data for ESM22-CME starting at 2022-03-10 17:13:58.225000 | 2022-03-10 17:14:09.971 Socket (3) | CloseSocket call. | 2022-03-10 17:14:09.971 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-10 17:14:09.971 Historical data download thread signaled to stop. | 2022-03-10 17:14:09.971 HD Request # 4 | Timestamp of first Intraday data file record written: 2022-03-10 17:13:59.506000 | 2022-03-10 17:14:09.971 HD Request # 4 | Received 33 Intraday data records from 2022-03-10 17:13:58.225000 to 2022-03-10 17:14:06.288003 (8.1 seconds) and wrote 14 records for ESM22-CME | 2022-03-10 17:14:09.971 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2022-03-10 17:14:06.288003 | 2022-03-10 17:14:09.975 Added 10 Time and Sales records to Intraday data file for ESM22-CME after download. | 2022-03-10 17:14:09.975 HD Request # 4 | Completion time: 0s | 2022-03-10 17:14:09.975 HD Request # 4 | Intraday data download complete for ESM22-CME. Unique request ID: 4 | 2022-03-10 17:14:09.975 Removing historical data download ID 4. | 2022-03-10 17:14:09.975 Real-time Intraday chart data file updates started for ESM22-CME | 2022-03-10 17:14:09.975 Intraday chart data file opened for ESM22-CME | 2022-03-10 17:14:09.975 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-03-10 17:14:09.975 Triggering next historical data download in queue. | 2022-03-10 17:14:09.975 No download requests in the queue to start downloads for. | 2022-03-10 17:14:09.975 Socket (3) | Socket gracefully closed by remote side. | 2022-03-10 17:14:10.035 Socket (3) | Closed. | 2022-03-10 17:14:10.035 Opened cached Intraday file: C:\SierraChart\Data\ESM22-CME.scid. Thread ID: 10596 | 2022-03-10 17:14:13.106 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-03-10 17:16:29.074 DTC Client socket (1) | Closed. | 2022-03-10 17:16:29.074 DTC Client socket (1) | Deleting network socket now after delay. | 2022-03-10 17:16:59.077 ESM22-CME 5 Min #1 | Reloading chart. | 2022-03-10 18:14:27.386 ESM22-CME #2 | Reloading chart. | 2022-03-10 18:14:27.409 ESM22-CME [CV][M] Renko 6t #6 | Reloading chart. | 2022-03-10 19:09:22.310 Unable to determine transition date based on volume from files: ESH22-CME.dly, ESM22-CME.dly | 2022-03-10 19:09:22.319 The ESM22-CME.dly symbol may not be the active contract month. | 2022-03-10 19:09:22.319 File >> Disconnect selected. | 2022-03-10 20:03:27.407 | Waiting for socket receive thread to end | 2022-03-10 20:03:27.408 DTC Client socket (2) | CloseSocket call. | 2022-03-10 20:03:27.408 | Disconnected from the server. | 2022-03-10 20:03:27.408 SC Data - All Services | Disconnected. | 2022-03-10 20:03:27.408 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-10 20:03:27.408 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-03-10 20:03:27.473 DTC Client socket (2) | Closed. | 2022-03-10 20:03:27.473 SC Data - All Services | Connected to server complete. | 2022-03-10 20:03:31.662 Triggering next historical data download in queue. | 2022-03-10 20:03:31.662 Triggering next historical data download in queue. | 2022-03-10 20:03:31.662 Triggering next historical data download in queue. | 2022-03-10 20:03:31.662 Triggering next historical data download in queue. | 2022-03-10 20:03:31.662 No download requests in the queue to start downloads for. | 2022-03-10 20:03:31.663 No download requests in the queue to start downloads for. | 2022-03-10 20:03:31.663 No download requests in the queue to start downloads for. | 2022-03-10 20:03:31.663 No download requests in the queue to start downloads for. | 2022-03-10 20:03:31.663 Mapping ESM22-CME to ESM22. Service code: cme | 2022-03-10 20:03:31.811 Using symbol data fast lookup vector | 2022-03-10 20:03:31.811 | Starting real-time market data updates for: ESM22-CME (ESM22). ID: 1 Service code: cme | 2022-03-10 20:03:31.811 | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-03-10 20:03:31.811 | Requesting security definition data for: ESM22-CME (ESM22). ID: 1 | 2022-03-10 20:03:31.811 Added historical Intraday data request for ESM22-CME to the queue. | 2022-03-10 20:03:31.811 Intraday data recording state for symbol ESM22-CME is set to download 'Pending'. | 2022-03-10 20:03:31.811 Triggering next historical data download in queue. | 2022-03-10 20:03:31.811 DTC Client socket (2) | Creating socket. | 2022-03-10 20:03:31.814 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-10 20:03:31.814 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-03-10 20:03:31.814 Delaying start of download for ESM22-CME | 2022-03-10 20:03:31.819 | Network connection to server complete. | 2022-03-10 20:03:31.891 | Starting socket receive thread. | 2022-03-10 20:03:31.891 | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-10 20:03:31.891 | Setting DTC encoding to Binary VLS | 2022-03-10 20:03:31.977 | Sending logon request message. | 2022-03-10 20:03:31.977 | Received logon response. | 2022-03-10 20:03:32.790 | Server Name: SC Realtime Server. | 2022-03-10 20:03:32.790 | Server protocol version: 8. Client protocol version: 8 | 2022-03-10 20:03:32.790 | Successfully connected. | 2022-03-10 20:03:32.790 | Trading is not supported. | 2022-03-10 20:03:32.790 | Restarting real-time data updates for symbol: ESM22-CME -> ESM22 | 2022-03-10 20:03:32.790 | Received security definition for symbol ESM22-CME | 2022-03-10 20:03:32.947 HD Request # 5 | Downloading Intraday chart data for ESM22-CME to the file ESM22-CME.scid. Service: cme | 2022-03-10 20:03:37.248 HD Request # 5 | Download start date-time: 2022-03-10 20:03:25.000000. File last date-time: 2022-03-10 20:03:25.638000 | 2022-03-10 20:03:37.248 HD Request # 5 | Using server: ds23.sierracharts.com port 10149 | 2022-03-10 20:03:37.249 Socket (1) | Creating socket. | 2022-03-10 20:03:37.249 Socket (1) | New receive buffer size: 5242880 | 2022-03-10 20:03:37.249 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-03-10 20:03:37.249 HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-03-10 20:03:37.395 HD Request # 5 | Sending historical data logon request message. | 2022-03-10 20:03:37.395 HD Request # 5 | Requesting Intraday data. Start date-time: 2022-03-10 20:03:25. Record interval: 0. Symbol: ESM22 | 2022-03-10 20:03:38.029 HD Request # 5 | Decompressing data. | 2022-03-10 20:03:38.095 HD Request # 5 | Receiving Intraday data for ESM22-CME starting at 2022-03-10 20:03:25.632000 | 2022-03-10 20:03:38.095 Socket (1) | CloseSocket call. | 2022-03-10 20:03:38.095 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 20:03:38.095 Historical data download thread signaled to stop. | 2022-03-10 20:03:38.095 HD Request # 5 | Timestamp of first Intraday data file record written: 2022-03-10 20:03:27.310000 | 2022-03-10 20:03:38.095 HD Request # 5 | Received 10 Intraday data records from 2022-03-10 20:03:25.632000 to 2022-03-10 20:03:32.043004 (6.4 seconds) and wrote 8 records for ESM22-CME | 2022-03-10 20:03:38.095 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2022-03-10 20:03:32.043004 | 2022-03-10 20:03:38.099 HD Request # 5 | Completion time: 1s | 2022-03-10 20:03:38.099 HD Request # 5 | Intraday data download complete for ESM22-CME. Unique request ID: 5 | 2022-03-10 20:03:38.099 Removing historical data download ID 5. | 2022-03-10 20:03:38.099 Real-time Intraday chart data file updates started for ESM22-CME | 2022-03-10 20:03:38.099 Intraday chart data file opened for ESM22-CME | 2022-03-10 20:03:38.099 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2022-03-10 20:03:38.099 Triggering next historical data download in queue. | 2022-03-10 20:03:38.099 No download requests in the queue to start downloads for. | 2022-03-10 20:03:38.099 Socket (1) | Socket gracefully closed by remote side. | 2022-03-10 20:03:38.164 Socket (1) | Closed. | 2022-03-10 20:03:38.164 Opened cached Intraday file: C:\SierraChart\Data\ESM22-CME.scid. Thread ID: 10596 | 2022-03-10 20:03:43.200 ESH22-CME 5 Min #1 | Reloading chart. | 2022-03-10 20:30:35.857 ESH22-CME 5 Min #2 | Reloading chart. | 2022-03-10 20:30:35.860 ESH22-CME 5 Min #3 | Reloading chart. | 2022-03-10 20:30:35.864 ESH22-CME 5 Min #4 | Reloading chart. | 2022-03-10 20:30:35.866 Mapping ESH22-CME to ESH22. Service code: cme | 2022-03-10 20:30:36.358 | Starting real-time market data updates for: ESH22-CME (ESH22). ID: 2 Service code: cme | 2022-03-10 20:30:36.358 | Requesting security definition data for: ESH22-CME (ESH22). ID: 2 | 2022-03-10 20:30:36.358 Added historical Intraday data request for ESH22-CME to the queue. | 2022-03-10 20:30:36.358 Intraday data recording state for symbol ESH22-CME is set to download 'Pending'. | 2022-03-10 20:30:36.358 Triggering next historical data download in queue. | 2022-03-10 20:30:36.358 Delaying start of download for ESH22-CME | 2022-03-10 20:30:36.361 | Received security definition for symbol ESH22-CME | 2022-03-10 20:30:36.521 HD Request # 6 | Downloading Intraday chart data for ESH22-CME to the file ESH22-CME.scid. Service: cme | 2022-03-10 20:30:41.246 HD Request # 6 | Download start date-time: 2022-03-10 05:19:00.000000. File last date-time: 2022-03-10 05:19:00.585001 | 2022-03-10 20:30:41.246 HD Request # 6 | Using server: ds21.sierracharts.com port 10150 | 2022-03-10 20:30:41.246 Socket (1) | Creating socket. | 2022-03-10 20:30:41.248 Socket (1) | New receive buffer size: 5242880 | 2022-03-10 20:30:41.248 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-03-10 20:30:41.248 HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-03-10 20:30:41.389 HD Request # 6 | Sending historical data logon request message. | 2022-03-10 20:30:41.389 HD Request # 6 | Requesting Intraday data. Start date-time: 2022-03-10 05:19:00. Record interval: 0. Symbol: ESH22 | 2022-03-10 20:30:41.915 HD Request # 6 | Decompressing data. | 2022-03-10 20:30:41.986 HD Request # 6 | Receiving Intraday data for ESH22-CME starting at 2022-03-10 05:19:00.585000 | 2022-03-10 20:30:42.130 HD Request # 6 | Timestamp of first Intraday data file record written: 2022-03-10 05:19:02.270000 | 2022-03-10 20:30:42.468 Socket (1) | CloseSocket call. | 2022-03-10 20:30:44.128 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-10 20:30:44.128 Historical data download thread signaled to stop. | 2022-03-10 20:30:44.128 HD Request # 6 | Received 954723 Intraday data records from 2022-03-10 05:19:00.585000 to 2022-03-10 20:30:39.210001 (15.2 hours) and wrote 954721 records for ESH22-CME | 2022-03-10 20:30:44.129 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-03-10 20:30:39.210001 | 2022-03-10 20:30:44.131 Added 70 Time and Sales records to Intraday data file for ESH22-CME after download. | 2022-03-10 20:30:44.131 HD Request # 6 | Completion time: 3s | 2022-03-10 20:30:44.131 HD Request # 6 | Intraday data download complete for ESH22-CME. Unique request ID: 6 | 2022-03-10 20:30:44.131 Removing historical data download ID 6. | 2022-03-10 20:30:44.132 Real-time Intraday chart data file updates started for ESH22-CME | 2022-03-10 20:30:44.132 Intraday chart data file opened for ESH22-CME | 2022-03-10 20:30:44.132 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-03-10 20:30:44.132 Triggering next historical data download in queue. | 2022-03-10 20:30:44.132 No download requests in the queue to start downloads for. | 2022-03-10 20:30:44.132 Socket (1) | Socket gracefully closed by remote side. | 2022-03-10 20:30:44.199 Socket (1) | Closed. | 2022-03-10 20:30:44.199 Opened cached Intraday file: C:\SierraChart\Data\ESH22-CME.scid. Thread ID: 10596 | 2022-03-10 20:30:48.219 ESM22-CME[M] 5 Min #4 | Reloading chart. | 2022-03-10 20:56:16.420 ESM22-CME[M] 5 Min #3 | Reloading chart. | 2022-03-10 20:56:16.857 ESM22-CME[M] 5 Min #2 | Reloading chart. | 2022-03-10 20:56:16.863 ESM22-CME[M] 5 Min #1 | Reloading chart. | 2022-03-10 20:56:16.867 ESM22-CME[M] 5 Min #4 | Reloading chart. | 2022-03-10 20:56:19.637 ESH22-CME 1 Min #1 | Reloading chart. | 2022-03-10 20:57:02.467 ESM22-CME [CB] 5 Min #2 | Reloading chart. | 2022-03-10 21:05:18.508 ESM22-CME #1 | Reloading chart. | 2022-03-10 21:06:09.825 ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:14.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:15.327 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:15.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:16.327 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:16.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:17.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:17.827 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:18.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:20.722 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:20.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:21.332 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:21.826 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:22.636 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:22.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:23.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:23.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:24.236 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:25.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:25.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:26.833 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:27.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:27.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:28.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:28.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:29.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:29.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:30.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:30.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:31.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:31.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:32.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:33.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:33.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:34.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:34.827 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:35.334 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:35.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:36.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:36.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:37.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:37.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:38.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:38.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:39.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:39.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:40.333 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:40.827 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:41.331 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:41.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:42.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:42.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:43.327 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:43.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:44.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:44.827 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:45.338 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:45.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:46.326 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:46.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:47.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:48.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:48.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:49.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:49.833 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:50.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:50.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:51.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:51.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:52.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:52.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:53.327 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:53.826 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:54.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:54.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:55.333 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:55.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:56.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:56.689 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:56.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:57.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:57.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:58.834 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:59.326 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:06:59.827 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:00.334 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:00.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:01.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:01.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:02.326 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:02.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:03.332 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:03.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:04.326 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:04.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:05.334 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:05.833 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:06.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:06.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:07.329 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:07.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:08.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:08.832 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:09.829 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:10.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:10.833 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:11.332 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:11.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:12.330 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:12.828 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:13.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:13.831 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:14.326 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:15.332 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:15.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:16.328 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:16.830 * ESM22-CME[M] #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2022-03-10 21:07:17.335 * |
| [2022-03-10 21:47:05] |
| John - SC Support - Posts: 47889 |
We really need to see an image of your chart. Please follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-11 02:07:53] |
| User795631 - Posts: 17 |
https://www.sierrachart.com/image.php?Image=1646964443781.png
| [2022-03-11 15:20:10] |
Everything looks good to us. We checked the time of the last bar in your chart, which was at 21:07:15 and we show the exact same price at that time. Additionally, your Chart Header shows a Data Delay of just 3 seconds, which can be caused by any number of things, including the time of your computer clock being off by those 3 seconds from what the exchange is sending. At this point, we have to say that everything on your Sierra Chart is looking good. We recommend checking the source of your other data to ensure that it is coming in correctly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
