Date/Time: Mon, 10 Mar 2025 02:20:59 +0000
Please check my last post - I need to know if this is possible.
View Count: 561
[2022-03-10 15:15:00] |
User92573 - Posts: 547 |
Hi John, I know you are all busy but can you or support answer my last post as soon as possible. I'd rather contribute to some Sierra programming than pay for the Jigsaw DOM as a side-by-side just for its DOM. Just really need to know if Sierra has any intention of adding the Limit with price improvement option to the platform any time soon. Many thanks |
[2022-03-10 16:32:56] |
John - SC Support - Posts: 38516 |
We just can't say. We are very busy and do not know if we will be able to get to any particular feature at any given time. We wish we could get everything done, but this is just how life works. You only have so many resources and it's a decision on where to spend them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-17 08:43:45] |
Understand. Many thanks.
