Date/Time: Sun, 09 Mar 2025 21:04:46 +0000
Flux réels Cbot
View Count: 416
[2022-03-10 15:11:57]
User241255 - Posts: 4
Bonjour,
Il est difficile d'obtenir les flux réels Cbot de Sierra Chart. Je veux simplement trader en simulation avec les flux réels de marché. C'est compliqué...
J'ai suivi vos conseils en demandant une ouverture de compte à Stage 5. J'ai validé les documents ce matin.
J'attends leur retour. Pouvez-vous de votre côté appuyer ma demande ?
Merci.
De plus, j'espère qu'ouvrir un compte à Stage 5 ne va pas m'occassionner des frais supplémentaires, etc...
Je suis déçu que pour trader en simulation avec des flux réels, il faut effectuer beaucoup de procédures.
Merci de votre compréhension
Dylan Deux
[2022-03-10 16:30:11]
John - SC Support - Posts: 38516
It is difficult to get actual Cbot feeds from Sierra Chart. I just want to trade in simulation with real market flows. It is complicated...
I followed your advice by requesting an account opening at Stage 5. I validated the documents this morning.
I await their return. Can you on your side support my request?
Thank you.
Also, I hope that opening a Stage 5 account won't incur additional fees, etc.
I'm disappointed that in order to trade in simulation with real flows, you have to do a lot of procedures.
thank you for your understanding
Dylan Two
It is the CME Group that makes this difficult. They have the requirement that you have to have a live, funded, futures trading account in order to get the data at the non-professional rates. We are just enforcing their rules.
As such, there is nothing we can do until you get your account setup and then connect Sierra Chart to that account. This is how we validate that you have the actual trading account setup.
This is also why we have our Delayed Streaming data that acts like the real-time data. It allows you to trade in simulation mode without having to pay any additional fees or have any special accounts in order to get the data. We really recommend just using this data instead of having to get setup for real-time data. Refer to the following:
Delayed Exchange Data Feed
