Date/Time: Fri, 25 Sep 2026 15:56:37 +0000
Unable to connect
View Count: 1093
| [2022-03-10 11:53:19] |
| noname - Posts: 16 |
I am Unable to connect to advantage futures and unable to see my open orders online.
| [2022-03-10 12:09:38] |
Able to cancel my orders. Called Advantage Futures -- Directed me to CME firmsoft
Date Time Of Last Edit: 2022-03-10 12:10:06
| [2022-03-10 13:13:59] |
We need you to get you off of this TT based order routing service immediately. We are going to contact Advantage about this. Please stop trading, until we get you off of TT. The problem you are experiencing is related to Trading Technologies and is making us look poorly. We are terminating the service at the end of this month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-10 13:15:36
| [2022-03-10 13:19:54] |
Also update Sierra Chart following these instructions: Software Download: Fast Update Contact Advantage to cancel any orders you need to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-10 13:20:01
| [2022-03-10 13:24:20] |
We have contacted Advantage right now about moving your account to our Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 13:29:16] |
Ok I will update my Sierra chart, so I just wait until advantage moves me to a new order routing?
| [2022-03-10 13:42:53] |
Yes. We did contact them. Please also let them know you want to move to Teton order routing: Sierra Chart Teton Futures Order Routing Since you have to ultimately be the one who authorizes this change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 14:58:54] |
Ok i have contacted them, does my Data feed need to be working in order to download sierra chart current version?
| [2022-03-10 16:11:37] |
| John - SC Support - Posts: 48013 |
There is no connection between the data feed and updating your system. Just select Help >> Download Current Version to update to the current, most recent, version. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 16:41:59] |
I am getting an error message Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2022-03-10 11:38:54.689 * Failed to download installer program due to an error. Request ID: 2. | 2022-03-10 11:38:54.689 * |
| [2022-03-10 17:06:49] |
Select the following link which will download the Installer program for you. Then run that downloaded program and make sure the folder for your Sierra Chart installation is set properly when you perform the upgrade/installation. Let us know if you have any issues with this: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-10 17:16:57
| [2022-03-10 17:16:24] |
Try flushing the DNS cache. Refer to step 4 in this section here: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-10 17:21:07] |
its not working, error says i am not using "not using http proxy server settings." i sent full log to support, no way of copying and pasting in the installer window |
| [2022-03-10 23:11:04] |
I use Parallels to run sierra chart, the issue was coming from Parallels, i have solved it now. thank you.... i have also connected to teton routing.
| [2022-03-10 23:42:56] |
Ok but still it is very important that you moved to Teton routing anyway. Since we will be closing down the TT based service.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-10 23:43:03
