Date/Time: Mon, 10 Mar 2025 03:02:54 +0000
How can I add the Menu bar back to the chart?
View Count: 828
[2022-03-10 06:43:02]
UserSwallowchin - Posts: 6
The File, Edit, Chart, Analysis...etc., menu bar has been removed from the template chartbook that I have received, how can I add the menu bar back to the individuate charts?
Many thanks!
[2022-03-10 14:25:38]
vp_ftw - Posts: 12
In the top left of the chart, you likely have the region1 data line visible with the symbol visible in the top left of chart drawing area.. Right click -> Show Menu
[2022-03-14 21:08:03]
Refer to:
Chart Menu: Show Menu (Chart menu)
