Date/Time: Sun, 09 Mar 2025 21:12:08 +0000
Using CQG app when Sierra Chart is open on computer
View Count: 495
[2022-03-09 23:49:17]
ssangha84 - Posts: 126
Hello, I am not able to use the CQG app on my iphone when Sierra Chart is left open on my computer. Is there any way to allow this?
[2022-03-10 15:15:52]
John - SC Support - Posts: 38516
We have no idea. You would need to ask your broker why this is the case.
If we had to guess, we would think it is because you are then making multiple connections to the data feed for which you are not setup.
[2022-03-10 16:30:49]
To avoid this problem use the Teton order routing service:
The Sierra Chart web-based trading panel provided with Teton allows you to have a connection at the same time as running Sierra Chart.
