Date/Time: Sun, 09 Mar 2025 20:55:49 +0000
Running SC in 2 computers
View Count: 423
[2022-03-09 20:50:40]
User958827 - Posts: 3
Good morning,
Is it possible, with the same Sierra account, to run the software in 2
computers at the same time, 1 in live trading and 1 in simulation?
F. Perbellini
[2022-03-09 21:05:25]
bdunn - Posts: 19
Yes you can do that.
I believe all the licenses allow for two systems. My license (package 12) allows for three.
Just fire up SC on another system and see how it goes. Should work fine.
[2022-03-09 22:15:13]
John - SC Support - Posts: 38516
User958827:
As bdunn states, you are allowed to run Sierra Chart on up to 2 different computers at the same time.
Just be aware that the exchanges have different rules, so if you are trying to connect to your data from both systems at the same time, you may have issues with that.
