Date/Time: Sun, 09 Mar 2025 20:40:14 +0000
teton order routing
View Count: 895
[2022-03-09 20:41:53] |
blackcobra777 - Posts: 28 |
hyw , i want to ask do i use teton futures order routing with interactive brokers too? if not then is there any way to use?
[2022-03-09 22:13:11] |
John - SC Support - Posts: 38516 |
Teton Order Routing is NOT available through Interactive Brokers. Interactive Brokers uses their own connectivity to the exchanges. In order to use the Teton Order Routing, you would have to have an account with one of the brokers listed in Step #2 of the Setup Instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
