Date/Time: Sun, 09 Mar 2025 20:59:48 +0000
Is it possible to separate Volume by Price study from other studies on DoM?
View Count: 480
[2022-03-09 17:51:13] |
CdoubleOkay24 - Posts: 3 |
Hi, I have my DoM setup to show my EMAs and the VBP studies and was wondering if it was possible to separate the studies into different columns on the DoM? Ideally if I could have my VBP values and histogram go into the Labels column on the right side of the DoM to replace the "Current Trade Total Volume" column and have my EMA Name labels still to the left so nothing is overlapping. I have tried swapping the value labels in the VBP settings to "Label Column" for each subgraph and changing the "Right Align Volume Bars" to Yes but haven't had any luck. Thanks for your time!
[2022-03-09 18:38:40] |
John - SC Support - Posts: 38516 |
The VbP can not be moved to within the Price Ladder columns. The only options to control the position of the VbP are Align to Right Side and Align to Far Right. Refer to the information at the following link: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
