Date/Time: Sun, 09 Mar 2025 21:00:51 +0000
Chart price change per bar , the setting number is a reference for what ?
View Count: 529
[2022-03-09 17:29:51] |
inusuel - Posts: 10 |
Inside : chart / chart setting / main settings /intraday chart bar period / bar period type I choose in the bar period type : price change per bar in the setting , the number means what ? Thank you |
[2022-03-09 18:17:03] |
John - SC Support - Posts: 38516 |
The Setting is how many price changes will occur before a new bar is started. Refer to the information here: Chart Settings: Price Change Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
