Date/Time: Sun, 09 Mar 2025 20:30:46 +0000
Number bar with no historic
View Count: 403
[2022-03-09 15:06:57] |
User250884 - Posts: 1 |
Hello, Since a few days I have no historic in my footprint. only few zero in the bar since the time I open sierra. I m with CQG. I try with sc historic data and it 's working with no zero issue. I don't have this problem before. I give you a picture for explain. Could you help me?? Regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62242 |
[2022-03-09 16:51:31] |
John - SC Support - Posts: 38516 |
Refer to the second bullet point at the following link which explains why you are getting this: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-09 16:51:32] |
