Date/Time: Sun, 09 Mar 2025 21:08:06 +0000
Auto Trade System Back Testing
View Count: 393
[2022-03-09 13:38:45] |
User39772 - Posts: 311 |
Hello, are the following observations correct. a) If I use sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED during Auto Trade System Back Testing a Buy Signal at a bar with "Index = 100" causes a fill at the Open of the following bar, i.e. the bar with Index = 101. b) If I do not use sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED during Auto Trade System Back Testing I understood, that the fill price is always based on the same bar that caused the signal and can be H/L/C/O of that bar, in the example above the bar with "Index = 100". If case b) is correct, is there a way to force an entry always at the close of the bar, i.e. to make that a part of the entry condition or could you provide such a function ? c) If I use attached orders for Target and Stop. Can I determine here if the exit is based e.g. on the bar high, or low, or close also ? Date Time Of Last Edit: 2022-03-09 13:39:38
