Date/Time: Tue, 26 Nov 2024 06:43:50 +0000
sierra real time data feed...
View Count: 1023
[2014-04-17 23:11:33] |
User53765 - Posts: 66 |
Hi Support, Can you tell me if the Sierra real time data feed with CTS account live or sim receives real time data for historical charts through the CME data feed or does it receive the standard Sierra historical charts that I would normally receive on a package 5 account without the real time data feed? Thanks. |
[2014-04-17 23:41:50] |
Also Support, In connection with my above question can you access the Sierra real time data on a CTS sim account for example but not a live funded account? Thanks again. |
[2014-04-19 06:22:19] |
Can you tell me if the Sierra real time data feed with CTS account live or sim receives real time data for historical charts through the CME data feed or does it receive the standard Sierra historical charts that I would normally receive on a package 5 account without the real time data feed? In connection with my above question can you access the Sierra real time data on a CTS sim account for example but not a live funded account? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-19 06:24:19
