Date/Time: Sun, 09 Mar 2025 20:35:21 +0000
commision
View Count: 555
[2022-03-08 17:17:40]
User491428 - Posts: 87
sierra does not calculate the commision ?
whats wrong?
imagetradeactivity.PNG / V - Attached On 2022-03-08 17:16:04 UTC - Size: 31.08 KB - 132 views
[2022-03-08 18:01:49]
John - SC Support - Posts: 38516
Refer to the following:
Trade Activity Log: Use Commission
[2022-03-08 18:20:20]
Yes, I’m understood. I have enabled “ use commission…”! I have refreshed, several times! But Sierra doesn’t!
[2022-03-08 18:46:51]
Did you also enter the Commission information in the Symbol Settings as the information in that section referenced?
[2022-03-08 19:37:17]
yes i have
imagetradeactivity.PNG / V - Attached On 2022-03-08 19:37:12 UTC - Size: 46.39 KB - 128 views
[2022-03-08 23:51:20]
Can you please give us an image of your Trade Activity Log now that you have the information in the Symbol Settings and that you have enabled the "Use Commission" button. Also, please specifically select the MES symbol to view just the information for it alone.
[2022-03-09 08:34:33]
hallo,
imagetradeactivity.PNG / V - Attached On 2022-03-09 08:34:27 UTC - Size: 45.2 KB - 127 views
[2022-03-09 15:39:12]
You still do not have the "Use Commission" option enabled on the Trade Activity Log.
[2022-03-09 15:52:34]
oh man, I'm looking everywhere for mistakes but I actually overlook this one. excuse me
