Date/Time: Sun, 13 Sep 2026 04:04:43 +0000
[Programming Help] - thread safe
View Count: 724
[2022-03-08 15:22:47]
User824913 - Posts: 15
Hi to everyone,
Is a global method defined like the code below safe?
Is there a danger of another studio running the same code at the same time with a different thread? In this case is it possible to synchronize a method?
Thks a lot
// The top of every source code file must include this line
#include "sierrachart.h"
// For reference, refer to this page:
// Advanced Custom Study Interface and Language (ACSIL)
// This line is required. Change the text within the quote
// marks to what you want to name your group of custom studies.
SCDLLName("Provette")
void test(int i){
//do the job
SCSFExport scsf_Provette(SCStudyInterfaceRef sc)
Date Time Of Last Edit: 2022-03-08 15:28:26
[2022-03-08 16:33:29]
Tony - Posts: 725
I would assume it's safe, I am using a few global functions.
My situation is I have 2 studies, let's say, Provette1 and Provette2, both
need to call test(), that was when things could get messed up, what I did
was having some public arrays, example: int result[2] = {0,0}; and Provette1
always writes result in result[0] and Provette2 in result[1], it works very
well, maybe there are better solutions.
(all public variables can be accessed by all studies, even between different
charts in the same chart book, which is very handy)
int result[2] = {0, 0};
double other_result[2] = {0.0, 0.0};
void test(int i, int result_target){
//do the job
result[result_target] = whatever_integer;
other_result[result_target] = whatever_double;
SCSFExport scsf_Provette1(SCStudyInterfaceRef sc) {
//codes
test(whatever_input, 0);
SCSFExport scsf_Provette2(SCStudyInterfaceRef sc) {
//codes
test(whatever_input, 1);
Date Time Of Last Edit: 2022-03-08 16:43:07
[2022-03-08 16:44:20]
Tony - Posts: 725
sorry, I forgot to add the calling part, just edited the previous post
[2022-03-08 17:35:31]
User431178 - Posts: 905
There is no problem with global functions and thread safety, unless the functions are accessing/operating on data that is available to/used by the various threads simultaneously (e.g. global variables).
Also, the charts/studies in SC are processed sequentially on a single thread, so, unless you are creating threads yourself, there should be no problem anyway.
Date Time Of Last Edit: 2022-03-08 17:35:51
