Date/Time: Sun, 09 Mar 2025 20:53:16 +0000
Connexion Rythmic
View Count: 895
[2022-03-08 15:13:37] |
User241255 - Posts: 4 |
Bonjour, Je viens de payer un compte financé Apex funding. Ils m'ont communiqué des identifiants Rythmics. J'ai essayé de me connecter avec ces identifiants dans Sierra mais cela ne fonctionne pas. Je n'ai pas les flux. J'ai lu qu'apparemment vous n'autorisez plus Rythmic. Mais je suis complètement bloqué, je ne sais pas comment je peux avoir les flux réels tout en tradant avec Apex Funding. J'espère que vous pourrez m'apporter une solution car j'ai choisi Sierra Chart pour trader avec Apex funding. Je suis bien embêté. Merci pour votre soutien. |
[2022-03-08 17:32:16] |
John - SC Support - Posts: 38516 |
From Google Translate: Hello,
I just paid for an Apex funding funded account. They gave me Rythmics IDs. I tried to login with these credentials in Sierra but it doesn't work. I don't have the feeds. I read that apparently you don't allow Rhythmic anymore. But I am completely stuck, I don't know how I can have the real flows while trading with Apex Funding. I hope you can give me a solution because I chose Sierra Chart to trade with Apex funding. I'm quite annoyed. Thank you for your support. First, make sure you are properly connected to your Apex account by following these instructions: Rithmic Trading Platform Service: Setup Instructions Note that Apex will have to tell you what server you should be connected to. Second, make sure you are aware of the data available from Rithmic by referring to the following information: Rithmic Trading Platform Service: Rithmic Support Policy Given the above data issues, we recommend using the Denali Exchange Data Feed. But, if you are needing data from the CME Group, then you will need to have a live, funded, futures trading account that you can connect your Sierra Chart to once a month, in order to qualify for the CME Group non-professional exchange fees. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Note that the Apex account does not count towards this requirement. If you do not have another trading account, then we recommend the service outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-08 18:26:06] |
TotalBeast598255 - Posts: 1 |
Hey Bud! What I do , (im funded with Apex) is to use Denali Exchange Data Feed on Sierre chart,and then I just execute trades on Ninjatrader 8. Works wonder, no issues whatsoever. Regards OtaconVault |
