Date/Time: Sun, 09 Mar 2025 20:39:17 +0000
Realtime data feed for CEUH22-ICEEU
View Count: 473
[2022-03-08 08:49:14] |
David Abrahams - Posts: 17 |
Hi! How can I changemy subscription or upgrade in order to receive realtime data for CEUH22-ICEEU ? Thanks in advance. |
[2022-03-08 15:51:58] |
John - SC Support - Posts: 38516 |
We no longer have real-time ICE data available. You can check with IQ Feed if they have what you want. Refer to the information here: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-08 16:22:50] |
Ah,, Ok. Thanks John.. Also, I seem only to havbe the 10 minute delayed data for ESH22-CME (e mini S&P).. how do I activate live data please? |
[2022-03-08 17:59:29] |
In order to get real-time data for the CME Group (which ES is a part of) you need to go through the setup instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* But, before you do that, make sure you are aware of the CME Group requirement that you have a live, funded, futures trading account that you can connect to at least once a month in order to qualify for the non-professional CME Group exchange fees. For more information, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that can qualify for this, then we recommend the following service: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
