Date/Time: Sun, 09 Mar 2025 21:10:22 +0000
Issues With Chart Replay
View Count: 605
[2022-03-08 05:04:11] |
Sergio Hernandez - Posts: 23 |
Im having issues with the chart replay feature. For example, Im trying to review today's session 3/7/22, but when I select play Im only seeing data up untile 3/3/22. Any insight into why this is happening? I've gone throught some standard troubleshooting. Thanks in advance. Best, Sergio H |
[2022-03-08 15:37:48] |
John - SC Support - Posts: 38516 |
What kind of replay are you using and are you replaying one chart or multiple charts? Also, does the chart on which you are starting the replay have data through March 7, 2022? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-11 23:32:16] |
Appologies for the delay in response. The scope of the issue was bigger than I though & more data related. Issue is now resolved. Thank you! Best, Sergio H |
