Date/Time: Mon, 25 Nov 2024 10:19:26 +0000
Volume by price - last N days
View Count: 551
[2022-03-08 02:16:56]
User19165 - Posts: 346
I would like to create a single profile of the last N days only and excluding the current day. This should reset itself every subsequent new day upon the market open.
What settings do I need? I so far can only make it plot the last N days but it will include the current day. I do not want that contamination.
[2022-03-08 15:36:07]
You would have to use the Volume Graph Period Type of From Start Date Time + Fixed time Length and set the beginning date back N + 1 days and set the number of days to N. Refer to the following:
Volume By Price Study: From Start Date-Time + Fixed Time Length
Keep in mind you would have to update this each day.
[2022-03-09 00:02:28]
It doesn't work.
Private File
[2022-03-09 00:16:02]
It does work, but it is including the weekend as days, so your setting of 3 days has Friday, Saturday and Sunday data. You will have to adjust as necessary to get what you need.
