Date/Time: Wed, 19 Mar 2025 13:44:14 +0000
Order fill connecting lines
View Count: 1963
[2022-03-08 00:34:11]
User148596 - Posts: 217
Hi, is there a way to change the width and color of the order fill connecting lines? I couldn't find it in global graphics settings.
[2022-03-08 15:13:03]
John - SC Support - Posts: 38782
Refer to the information at the following link and the item after it:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Entry/Exit Connecting Lines Primary
[2022-03-08 16:27:34]
Thank you, however nothing in those instructions actually says how to change the color, width or style of the connecting lines. It just shows how to enable order fill connecting lines and color them based on P&L but not how to manipulate the color, width or line style (even though in the description it claims to it does).
[2022-03-08 18:00:56]
When you go to those entries in the Graphics Settings, you can change the Color, Style, and Width of the entries which changes them for your charts.
[2022-10-25 22:47:41]
SamGeorgev - Posts: 19
For those who still have this issue please follow this:
1. Open Chart Graphic Settings (not from the global setting board)
2. On the Colour and Width section scroll down to
Chart Trading Order Fills Entry/Exit Connecting Lines Primary (Buy)
Chart Trading Order Fills Entry/Exit Connecting Lines Secondary (Sell)
3. You choose the width and colour and apply to see the difference immediately
Hope that helps as mr.John did not bother to explain it
