Date/Time: Sun, 09 Mar 2025 20:29:07 +0000
setting to not show chart list at bottom of chartbook
View Count: 1273
[2022-03-07 22:46:20]
User73630 - Posts: 19
I am installing SC on a new computer and I've imported my chartbooks from other computer. However, when I open a chartbook, at the bottom of the chartbook is a list of all the charts in my chartbook. I know there is a way to uncheck a setting so that doesn't show them. I've searched but couldn't find that setting. Please help. Thanks
[2022-03-07 23:03:41]
John - SC Support - Posts: 38516
There is not a way to not show the chart (MDI) tabs that shows the charts that make up the Chartbook.
You can change the position of the tabs, refer to the following:
General Settings Window: Show MDI Tabs At (Global Settings >> General Settings >> Windows >> Window Tabs)
And you detach charts so they are not managed by the program, in which case the tab will not show, but the chart will show as a separate window in your Task Bar. Refer to the following:
Window, CB and CW Menus: Detach/Attach Window (Window)
And you can Hide charts, which will remove the tab for that chart, but as soon as you go to view that chart, it will become visible and the tab will show again. Refer to the following:
Window, CB and CW Menus: Hide Window (Window)
